For normal driving, get Autozone Duralast rotors or something. Rotors are just an iron slab and you don't need to spend a lot on them! Drilled rotors are basically pointless and can be prone to cracking.
FWIW, I run Duralast rotors on my 1992 and autocross it every weekend, they're perfectly fine. I also use Hawk HPS pads up front, which I wouldn't buy again due to their terrible cold bite. Great once warm though.
A vendor here has a good deal on slotted & drilled + ceramic pads for about 2 bills. Since it's just for the street they will not crack as someone said and will enhance the look greatly. I had them before I started racing and they work just fine.
Check out the Carbotech 1521 brake pad, a description is below and pair that with some Centric premium rotors you cant go wrong. If interested let me know I will be happy to help you
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Are these stock rear sizes? Looks maybe like a +1. Been thinking of some Decelerotors in stock sizes until I do a BBK.
