C4 85 stock tune upgrade
As for Pe tables you sure advice me to work on to lean out ,i have a 870 ECM and only this PE appears,i've opened some othe tables just in case:
[IMG]
[/IMG]
Also, under heavy load at WOT is the worst time to get detonation, and a rich mixture helps to prevent it.
You will be at WOT for a relatively short time. If you're not racing and looking for ultimate power you're better off leaving it rich.
Change your WOT vs coolant temp table from 22.66 to 15 and see where the WOT AFR is. After that change your WOT vs RPM table to negative numbers to try and lean the car up to mid 12's at WOT. Your PE spark is zero because the tuner probably added in all the additional spark timing in the main spark table. I see that your main spark tables are in the upper 20's until 4800 RPM where it goes to 32 degrees. This timing appears to be safe I would probably play around with more timing since most SBC make best power with 32 to 36 degrees or WOT timing. From 3200 RPM and above at WOT I would set all of the timing at 32 to 36 degrees and see how it runs.
Do you have stock fuel injectors and fuel pressure? It appears to me that you may have increased the pressure or injector size without adjusting the tune for the change.
Is that 35 to 38 PSI with the vacuum line disconnected?
Also, mine idles pretty smooth at low 500's RPMs when warm, bouncing around no more than +/- 50 RPM so it sounds like yours is not idling right. I would check your BLMs and make sure everything is in line before you go too far on the tune.
BTW: I am also running an Ostrich. Great little box.
I was told the idle surge is because the camshaft is too big for the computer and it can't respond to the drastic changes in air/fuel ratio fast enough or something.
I don't know. He basically said that if I look at my O2 sensor on an oscilloscope, I'd see voltage going up and down, indicating rich/lean, rich/lean, rich/lean. He said every time it spikes upwards or spikes downwards that I'd probably hear it surge at the same time. He said when the RPMs raise, that voltage fluctuation on the O2 sensor will happen faster and the idle will seem smoother.
And I've noticed that too. My idle is set to target 1300 RPMs when really really cold. It slowly comes down, 1200, 1100, 1000. 900, 800 as it warms up. The idle doesn't surge until it reaches 800. So I may target 850 as a happy medium between lopey sound and smooth idle.
Just my experience. And I definitely think that you have a lot more power potential in the WOT AFR, and in your timing tables. From what I've learned with the extensive modifications that I've done, small things like that make the biggest difference.
I believe you are supposed to run in the 11:1 area stock at WOT. I would go all the way to 13:1, then work on timing.
BLMs may help if it's something like a vacuum leak.
You need to work on the tune, with the correct the idle. With the correct changes you can get it to idle. Make sure your idle AFR is close to 14.7, make sure your idle timing is stable, make sure your IAC motor is near 20 counts at idle, slow up or speed up your IAC steps per second to keep the engine stable (Adjust this one last).
Anyway, this may explain your excessive rich WOT. Low BLMs mean the PCM is leaning out the mixture during closed loop, but during PE a narrowband O2 won't provide any useful data so it goes into open loop. If the BLMs are low (as in your case) the PCM disregards them and resets the BLM to 128 -- meaning the AFR at WOT is relatively over rich compared to closed loop.
I suspect if you get your BLMs in closed loop close to 128 you will find your WOT AFR will go up to the 12's which is where it should be. Mean best torque can usually be achieved over a broad range of AFRs but until you get way too rich there is really no power loss. As such I would always err on the side of safety (low AFR) like Cliff suggests above. Definitely keep it below the 13s. Rule of thumb is something like 0.8 lambda or 11.8 AFR.
There is another thread going which ends up discussing whether high BLMs are used to enrich WOT. It seems like in some cases they are (though this doesn't apply to you):
http://forums.corvetteforum.com/c4-s...post1586726803
