Mine is mounted under the front (pass.) headlight in the nose of the car. You can make a shield to keep it from getting wet. :yesnod:
Mounting it this way... its away from all the heat.
Installed 4+years ago.
If I remember I will try to take some pics of it this weekend.
same here, remind me to take some pics & send you tomorrow rich, you might have to re-arange some of your garbage though :p: i was a little side tracked tonight when you called :blueangel:
here's where mine is however i have it all tore apart & haven't figured out where i'm going to put my rev limiter box {i have a 6t people with 6al's have it easier} i also mounted the coil on my drivers side inner fender kind of by the master cyl. also here's the red powder coat i was telling you about & planned on showing you before i got side tracked.
I put it on the driver side, Like in the picture of Gtsyellows car. The MSD wire kit that you buy extra is a good thing to get :yesnod: :yesnod: There are no wires to splice into with the kit. That is a big plus in my book..
