insulation wrap
Old Apr 21, 2014 | 08:08 PM
cormorant71's Avatar
cormorant71
Default insulation wrap
Hi everyone,
On to my next project, thanks again for all the help with the stuck headlight.
The insulation wrap on the passenger side of the engine is in tatters. What can I use to replace it.
It is the wrap on a metal pipe that leads from what looks like the exhause to the intake? I think...
It is just forward of the transmission dipstick.
Chris
Old Apr 21, 2014 | 08:19 PM
don hall's Avatar
don hall
Amazon.com (just copy paste bold description)
Product Details
BLACK High Temperature Header Exhaust Pipe Insulation Wrap Roll Black 1/8" X 1" X 50' - Thermal Zero
$16.95
Only 8 left in stock - order soon.
Use two small worm clamps..... one positioned at the top, then slowly wrap and push up the insulation for a smooth look.
Use the last clamp at the end. Measure the approx amount of insulation needed and cut from the roll.
Old Apr 21, 2014 | 08:22 PM
John A. Marker's Avatar
John A. Marker
That is the EGR tube that goes from the exhaust with hot exhaust gases to the intake.
Old Apr 21, 2014 | 08:27 PM
Dt86's Avatar
Dt86
Heres one place
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Apr 22, 2014 | 04:39 AM
Cliff Harris's Avatar
Cliff Harris
The aftermarket EGR heat shields are junk. The heat destroys the Velcro and you get this:
The solution is to put header wrap on the EGR tube before putting on the heat shield:
Another hint: The aftermarket heat shields go on "backwards" and the seam shows. If you cut a new hole in the diagonally opposite corner then the seam does not show:
Old Apr 22, 2014 | 05:23 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I put header rap on my tube but placed it length wise on top and bottom and stapled along the sides, I think it looks better than rapping it.
Old Apr 22, 2014 | 07:31 AM
Dt86's Avatar
Dt86
Good to know. Thanks for the info
Old Apr 22, 2014 | 08:04 AM
WW7's Avatar
WW7
If you do go with the velcro wrap, use about 3 of the little metel straps ( they are actually metel zip ties) to secure the wrap at the top , bottom, and middle...This will keep it secure when the velcro fails...I used these on my starter insulation wrap...WW
They are cheap and this is what they look like.....
http://www.ebay.com/bhp/stainless-steel-zip-ties
Old Apr 22, 2014 | 09:41 AM
mixalive's Avatar
mixalive
Great thread.
Old Apr 22, 2014 | 03:08 PM
cormorant71
Very helpful!
thanks again to everyone
chris
Old May 13, 2014 | 09:14 PM
MikeT 90 C4sixer's Avatar
MikeT 90 C4sixer
Well i just got the velcro wrap from Corvette Central....should i use it? Better to wrap it with the pipe off? Mine is off now, and it appears that i have to cut the wrap to fit correctly. is the header wrap readily available? that does look like a good idea. shoulda done a search on this before i bought a wrap.
Old May 13, 2014 | 09:19 PM
BOOT77's Avatar
BOOT77
I tried too save my tube to sell someday, but I ended up making a mess of it and the het wrap. It was in really good shape and I'm betting newer since they didn't have the intake side gasket on it.
To insulation wrap
