Autoxray xp240
Old Apr 24, 2014 | 06:20 PM
charliet615's Avatar
charliet615
Default Autoxray xp240
Can anyone give me some instructions on how to use this Scanner?
I've had no luck on the Scan and Tune Site..
Old Apr 24, 2014 | 10:00 PM
jv9999's Avatar
jv9999
If it's like mine, you power it on, turn the ignition on (but don't start it) and hit "scan". It should come back with "scan successful". After that you can get the codes or read the operational parameters in real time (RPM, O2 values, cross counts, injector pulse width, etc).
Old Apr 24, 2014 | 10:11 PM
charliet615
Sir, you are a gentleman, thanks for that info. I'll give it a try..
Old Apr 24, 2014 | 11:52 PM
HlhnEast's Avatar
HlhnEast
You hafta enter info 1st to set it up to scan. I have the same scanner and its the OBD1 bomb. Heres what you have to do to start.
1) Press CONFIG. Use the UP or DOWN key to Select 1, 2 or 3 to set up the spot for your car. Then press CONFIG again.
2) The display will show manufacturers. Select GM using the NEXT or BACK key then press CONFIRM/ENTER. THe display will advance to the final step.
3) Select the 8th number of your car's VIN and press CONFIRM/ENTER.
4) You will see the car's description displayed and IIRC you will have to enter "Y" for Corvette.
5) If thats all you want to configure for now, press CONFIG/ENTER.
At this point you are ready to go. Plug 'er up and turn the key to on, engine off press SCAN and thats it to check for codes. You can start the car and use the MON key to capture data from various sensors or review the info at a later time. It will capture 14 seconds of info to display. At that point just scroll to get your info.
Good luck and get scannin!
Oh and dont forget to remove the batteries if its going to sit for a long time. You will lose all stored data but its better than getting corrosion all in your scanner.
Old Apr 25, 2014 | 06:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed it sounds like you just to set up the config. for your particular car.
You can gain quite a lot if insight into engine operation and tune from the unit.
Old Apr 25, 2014 | 09:42 AM
charliet615
Thanks Guys, i really appreciate all your help...It's great to have a Forum that helps a Guy like me.. I don't like paying a Shop $85 an hour just because i have not tried to fix it myself.
Old Apr 25, 2014 | 07:42 PM
HlhnEast's Avatar
HlhnEast
Thats what its all about. Ask when you need and contribute when you have answers. This is a great place and I have received more answers and info than the law allows.
Old Apr 26, 2014 | 05:26 AM
65Z01's Avatar
65Z01
Part of the fun is learning about our cars and then being able to help others in return...
To Autoxray xp240
