Steering Assistance Please
Old Apr 27, 2014 | 11:44 AM
popo8's Avatar
popo8
Default Steering Assistance Please
HI everyone... Hopin someone can help me. I did try searching, however from my phone...its glitchy...and my laptop is broken.
I know on the 4th gen fbodies...its an upgrade to get rid of the steering shaft with the rag joint, in exchange for an LS shaft.....????? is there a similar mod for the earlier c4s?
My 85 has alot of play in the steering...and Id really like to tighten it up.
Any advice or help would be greatly appreciated.
LTXtech.com is my DRUG!
Old Apr 27, 2014 | 03:52 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Have you checked the basics first? Tie rod ends, rack?
Old Apr 27, 2014 | 03:58 PM
popo8's Avatar
popo8
I have,,, I know what the problem is...and if it was a fourth gen fbody...I know what the fix is, as stated above.
However I DONT know if the c4s have a similar fix...upgrade, THAT is why I asked the question about the "upgrade," here.
Old Apr 27, 2014 | 04:12 PM
WVZR-1's Avatar
WVZR-1
You can have a Borgeson shaft constructed for anything. I don't believe they do a shaft assembly for a C4. I would think it not an issue to send them the shaft and have it fabricated.
You could actually construct it yourself I believe with the correct DD joints and a DD shaft. I believe the C4 is 17mm DD at the rack and 1" DD at the column. That would need confirmed but I'm quite confident.
Old Apr 27, 2014 | 04:21 PM
popo8's Avatar
popo8
Ok... But outside of a custom made piece..there is no upgrade that is done by swapping out a piece that comes from a newer or later model c4 or vette?
SEE the lt1 fbodies utilize a rag joint in the shaft...after tine...it wears out...hence the play. In 98 the ls fbodies eliminated the rag joint..and that same swap into the older fbodies is the "upgrade/fix" removing that play in the wheel.
I thought at one point I had read someone having an upgrade like that on here... But i cant seem to find it utilizing the search here.
Old Apr 27, 2014 | 04:56 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ahh, well, apologize for confirming the basics first. As you were.
Old Apr 27, 2014 | 04:59 PM
popo8's Avatar
popo8
Lol.. Np.
WVZR-1's Avatar
WVZR-1
I've never needed one and I've not investigated the use of something "other than" the original. It might be an interesting call to Borgeson for you and post back. The very early C4 didn't have a rag joint and they were frequently drilled and pinned, some I believe were actually welded also. I also only saw your reference to "RAG JOINT" in your original post and I later see that it's an '85 and I don't believe it will have a "rag joint".
Old Apr 27, 2014 | 05:08 PM
popo8's Avatar
popo8
I ref to "rag joint" because im comparing to the upgrade on the fbodies. Known problem is the rag joint... "KNOWN" Fix =`s replacing it with a shaft that does not utilize a rag joint.
As for the c4 and "welding"....what are u refering to that would be welded?
Old Apr 27, 2014 | 05:17 PM
WVZR-1's Avatar
WVZR-1
You need to inspect yours first and I believe it would become obvious as to what could be done to accommodate a "fix". Welding would eliminate the collapsible aspect of the shaft but it's been done.
here's an eBay with an early intermediate shaft that the seller has mis-advertised but it's what I believe you should find in your '85. You can "zoom" this for a closer look. You can or should be able to feel the problem in yours under the hood. Determine from that I guess if you'd be happy with what others have done.
http://www.ebay.com/itm/1985-corvette-intermediate-shaft-1984-1986-1989-1988-1989-/331071786656?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d156a8ea0&vxp=mtr
Corvette Central offers a reconditioned one. Enter 7843500 in the part # search box:
http://www.parts123.com/parts123/yb....ort~A2~cadefib
Old Apr 27, 2014 | 11:12 PM
popo8's Avatar
popo8
1985 Corvette Intermediate Shaft 1984 1986 1989 1988 1989 | eBay
Corvette Central offers a reconditioned one. Enter 7843500 is the part # search box:
Im thinking maybe I was not clear with my issue.. There is not issue with the collapsability of the shaft, but rather play or slop in the wheel.... Im not sure what welding or "pinning" the shaft so that it would not collapse during impact would do for left and right slop.
Or maybe Im misunderstanding you... idk.
Old Apr 27, 2014 | 11:58 PM
WVZR-1's Avatar
WVZR-1
Drilled and pinned or weld can/could eliminate the left to right issue that you have presently. Pinning or welding also eliminates the collapsibility of the shaft from impacts. An issue? Maybe not, personal decision. Change to the later with a rag joint - done frequently.
Old Apr 28, 2014 | 12:45 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Why are we talking about rag joints and re-engineering the problem? What's wrong with fixing it the right way? Is your problem the intermediate shaft, the steering rack, or the tie rods? Please be clear. It sounds to me like you just need a good intermediate shaft! If you see movement of the pins that are perpendicular to the centerline of the intermediate shaft, that's your problem! I'd encourage you to fix it the correct way! You'll be good for another 30 years!
Old Apr 28, 2014 | 01:32 AM
WVZR-1's Avatar
WVZR-1
You'll notice I pointed out a reconditioned correct one in my post! There's no issues changing to the rag joint that's in the later C4's. That's not re-engineering anything, GM did it!
Old Apr 28, 2014 | 10:23 PM
Hot Rod Roy
No antagonism intended. Is the rag joint mod any improvement? Is it a bolt-in change? Drilling and welding on your steering shaft is an invitation for disaster (IMHO)!
I know the fix of replacing the intermediate shaft is easy, effective, cheap, and reliable!
Old Jan 29, 2021 | 05:35 PM
billelovski's Avatar
billelovski
Cruising
I have this same issue with my 1985. The slip portion on the intermediate shaft has a lot of slop in it. Any help would be appreciate. I can't seem to find a remanufactured one. I am at the point of removing it now that I know it is the cause of my loose steering.
Old Feb 1, 2021 | 01:40 PM
ctmccloskey's Avatar
ctmccloskey
I would probably call Turn One and see what they say. They are experts on anything to do with the steering system in a C4. They are online and easy to find.
My rack was sloppy and making noises so I had Turn One rebuild it for me. It is tight and just like a new car "tight". The suggestion they had for me was "Keep the Power Steering Fluid COOL" and your seals will last a lot longer. I have done this on my C3 but not yet on the C4.
I am anxious to learn a way to install Electric Power Steering and get rid of the old power steering system altogether. I would like to do the C3 first and then maybe the C4.
Old Feb 2, 2021 | 09:18 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thread is 7 years old, guys. I don't think the OP will see it.
To Steering Assistance Please
