Lubrication points for 4+3?
Old Apr 27, 2014 | 10:20 PM
volkswagens-for-life's Avatar
Default Lubrication points for 4+3?
My 4+3 feels very 'dry'. It feels like it needs a major grease job. Aside from opening the top of the dash and globbing grease onto everything I see, are there special lube points for this shifter assembly?
Old May 5, 2014 | 07:53 PM
Nobody?
Yesterday I shot up the linkage of the shifter (through the hole in the shifter boot) and sprayed it all down with bike chain lube. That helped a TON, and the shifter doesn't sound like pure metal on metal while shifting anymore, but it really needs more. I know there is room to go w/ lubing up that shifter assembly. Make I should be using white lithium grease instead?
Old May 5, 2014 | 08:27 PM
S S0DEN's Avatar
S S0DEN
I don't think it has traditional lube points like your thinking, but you can see the linkage with the car on jack stands. I would change the fluid while your there if it's giving you problems.
Old May 5, 2014 | 09:11 PM
1985 Corvette's Avatar
1985 Corvette
We use to have a poster by the name of Centralcoaster who kept a page on his updates on his 85 Vette. One of those, before he got rid of the 4+3 altogether was removing the 4+3 shifter assembly, disassembling it, and retightening it together with a press. He noted it shifted much better after that.
Old May 6, 2014 | 09:44 AM
c4cruiser's Avatar
c4cruiser
White lithium grease would probably be better, but if the chain lube worked, then I would wait and see how well it works over time. Did you remove the rubber seals around the shift rods to spray the shifter mechanism?
Removing the shifter assembly is a PITA but with it being inside the car, there should be no real build up of road grease and dirt.
Old May 6, 2014 | 08:41 PM
Re tightening what with a press??? The linkage end pieces????? I must search now... thanks for the heads up man.
Before I sprayed the chain lube shifting kinda resembled nails in a coffee can. Rigid, rough, NOT smooth, noisy, kinda scrapey lol. Now its a lot better but I can tell not quite 100% sure. I didn't even lift the top part of the console though; I sprayed down the neck hole for the shift rod.
Old May 6, 2014 | 08:59 PM
c4cruiser's Avatar
c4cruiser
Does the neutral gate feel smooth when you move the lever side-to-side? This could also be an adjustment issue. The FSM has a procedure for adjusting the shifter.
Old May 6, 2014 | 09:09 PM
Its got a short shifter, so the side to side movement is REALLY tight feeling. IE the gates are very close together in my opinion. Probably not tremec or richmond 6spd close, but pretty darn close. It sounds a bit creaky (well, did... before the chain lube) going side to side though.
The best analogy for my situation is a rusty bicycle chain. It works, but it takes effort, its noisy, and not the most fast shifting.
Old May 7, 2014 | 08:28 AM
vetteoz's Avatar
vetteoz
Typical of most old skool ( esp when worn ) external linkage shifters ; are never going to feel like the int mech on a ZF6 or Tremec
Old May 7, 2014 | 05:30 PM
Haha I kinda figured as much but wasn't sure. Still think some white lithium lube would help any?
To Lubrication points for 4+3?
