Blown headgasket??
Old Apr 29, 2014 | 04:46 PM
Christian95's Avatar
Christian95
Good news! I found it! Bad news! It's my intake gasket! I decided to start her up and take a look so I watched the rear of the intake while I revved it and it squirted oil
Old Apr 29, 2014 | 05:36 PM
BOOT77's Avatar
BOOT77
Originally Posted by DanielRicany
The more pressure the better! 80 isn't too high. Mine is like 60 or 70 on a cold start.
More pressure is not always good, it can mean a restriction. For example a clogged filter and that's why some have a bypass and GM puts a bypass in sbc oil filter adapters(I'm not sure if corvette is different). People have blown off oil filters.
Old Apr 29, 2014 | 05:37 PM
STL94LT1's Avatar
STL94LT1
Intake gaskets are an easy fix on LTx cars.
Old Apr 29, 2014 | 05:47 PM
DanielRicany's Avatar
DanielRicany
Too bad it's an L98
Old Apr 29, 2014 | 05:52 PM
STL94LT1's Avatar
STL94LT1
Too bad it's an L98
Oops, I was looking at his user name and thought he had a 95.
Old Apr 29, 2014 | 07:11 PM
Christian95
Oil filter is new so it shouldn't be clogged. I'll check my pcv system just to be sure I don't blow another gasket.
And yup it's an l98. And yeah I didn't think about the confusion from my username lol that's actually the year I was born.
Old Apr 29, 2014 | 11:18 PM
lt4obsesses's Avatar
lt4obsesses
Well, an intake gasket is alot better than some other things it could've been.
And '95, holy cow, I've got boxer shorts older than you.
Old Apr 30, 2014 | 05:24 AM
Cliff Harris's Avatar
Cliff Harris
I found a house that goes to my throttle body from the vac system and it was unplugged.
Depending on the year, some L98 throttle bodies have a vacuum hose on the passenger side that goes to the vapor canister under the driver's side headlight. There is also a vacuum hose on the bottom of the throttle body that goes to the EGR solenoid.
Also there's a hose the goes from the passenger valve cover to the throttle body and it has oil inside of the hose.
That is the air supply for the PCV system. It takes filtered air from the throttle body and feeds it into the crankcase through the passenger side valve cover. On the driver's side, the PCV valve gets vacuum from the intake manifold to suck the oil vapors out of the crankcase. I recently found this little diagram (which is not for a Corvette, but the general idea is the same -- the PCV valve is connected to the lower intake, not the plenum):
There should not be oil in that hose if the PCV system is working correctly.
Old Apr 30, 2014 | 02:01 PM
Christian95
Thanks! That makes a lot of sense! I've had a lumpy idle for awhile too so maybe that's linked to the pcv problem
Old Apr 30, 2014 | 06:47 PM
Christian95
So if clean air is supposed to come from the throttle body, what is causing oil to come through? I checked my valve and it rattles and has suction
Old Apr 30, 2014 | 06:54 PM
DanielRicany
I believe that the port on the throttle body may be able to go both ways. I think I blew into it on mine and it went through, and when I sucked on it it came through also.
At high RPMs the hot oil gases may be forced out through the breather tube and into the throttle body. I noticed on mine it makes a lot of smoke from the breather filter that I converted to at high RPMs.
Old Apr 30, 2014 | 07:17 PM
Christian95
So I must have a clog somewhere under one of the valve covers then. Is there some kind of filter on the pcv valve side?
Old Apr 30, 2014 | 07:22 PM
  #33
DanielRicany
No, I converted mine to a filter, so it's aftermarket.
Old Apr 30, 2014 | 07:57 PM
  #34
Christian95
Would there be any change in idle if either side of the pcv hoses were unplugged? I unplugged them and nothing changed about the idle. Also there's nothing happening on the passenger side from the throttle body. No suction or air passing through at all
Old May 1, 2014 | 04:01 AM
  #35
Cliff Harris
You should have some vacuum on the passenger side valve cover opening (from the PCV valve). As I said earlier, the PCV sucks filtered air from the throttle body.
If you have oil in the passenger side tubing it usually means the PCV system is not working. Basically the only way to get oil in there is if the blowby is overwhelming the PCV system. That usually only happens in full race engines operated at WOT and high RPM (low vacuum at WOT) for sustained periods of time. That said, worn piston rings can cause this, but that is not at all common on these engines.
Old May 1, 2014 | 02:14 PM
  #36
Christian95
I'm hoping it isn't worn piston rings cause I only have 23k miles. Is the only way to check or unclog the pcv system by removing the valve covers?
