Blown headgasket??
Old Apr 28, 2014 | 10:27 PM
Christian95's Avatar
Christian95
Default Blown headgasket??
Hey all It's been awhile since I've been on here since my '90 383 was at the paint shop but I'm glad to be back!
now on to the bad news I have been chasing an oil leak for awhile but tonight I changed my alternator and started her up to check everything and it started normal but after a few minutes my idle rpms rose noticeably higher and not too long after smoke poured from the rear of the engine. Now I've always seen a small amount of smoke but this was alot and it even came inside the car. I believe the source is on the passenger side and when I changed my oil a few days ago I noticed my starter is soaked and there are drips rolling down my bell housing. Does this sound like a head gasket? Or rear main seal? Any help is appreciated! I'm about to head out and use a mirror and light to check and I'll get back with what I see. Oh and before I forget is there any certain areas that are most common to check for something like my situation? Once again thanks!
Old Apr 28, 2014 | 10:32 PM
don hall's Avatar
don hall
Sounds like a head gasket breach..... easily diagnosed by pressurizing the engine. Doubt a damaged rear main seal would allow oil into the combustion chamber.
Old Apr 28, 2014 | 10:42 PM
DanielRicany's Avatar
DanielRicany
Well Oil Doesn't Run Through The Head Gaskets On These Cars. If Its Indeed Oil, I Doubt Its A Head Gasket.
Old Apr 28, 2014 | 10:49 PM
Christian95
Definitely motor oil... I thought oil did run by the head gasket? But then again I have no idea. I caught a drip of oil on the passenger side and it seems to be under the spark plug. I don't mean the oil is coming from the plug but whats further under the spark plug the could leak oil? I seen a bolt but I couldn't see it well enough to see if it was leaking
Old Apr 28, 2014 | 11:08 PM
DanielRicany
Check Valve Cover Gasket
Old Apr 28, 2014 | 11:36 PM
Christian95
Would I be able to check it without taking it off?
Old Apr 28, 2014 | 11:39 PM
DanielRicany
Yes, Look For Wet Spots Or different Tints Of Color On The Motor Next To Them. Always Trace Leaks To The Highest Spot.
Old Apr 29, 2014 | 12:09 AM
Christian95
No wet spots around the valve covers but there's oil runs under my distributor. Not coming from the distributor though
Old Apr 29, 2014 | 12:21 AM
DanielRicany
There Is A Gasket Between The Block And The Intake That Seals From Oil In The Lifter Valley, Both Front And Rear of The Block.
Old Apr 29, 2014 | 12:25 AM
Christian95
There's a blue gasket I noticed on the front of the block that looks wet but that doesn't explain why most of the rear of the engine is oily
Old Apr 29, 2014 | 12:30 AM
DanielRicany
Because There Is Also One In The Rear
Old Apr 29, 2014 | 12:40 AM
Christian95
Got me to chuckle with that one lol so is it likely that both blew? I know I'm asking dumb questions but thanks so much for the help!
Old Apr 29, 2014 | 12:51 AM
DanielRicany
It Is Possible
Old Apr 29, 2014 | 12:52 AM
BOOT77's Avatar
BOOT77
If it's not your valve cover I'd say rear of intake gasket, had too replace the one on my 1st tpi car and when changing my dist noticed my C4 is leaking some. I'll be pulling the intake if I ever get my runners and use a good bead of permatex black for the intake ends like many do. Check your pvc, if it's bad could be building too much pressure and blowing out your gaskets.
Small chance it's the headgasket, I've read of mls multi layer head gaskets leaking oil. And oil does pass thru the headgasket, but that's not the exact spot or reason I've herd mls gaskets leak. I herd they sometimes leak at the point of the gasket and more so when your valley is flooded with oil.
Red drainback, Yellow mls leak area (note this is not a mls and it shows the front and not the rear, it's just an example)
Old Apr 29, 2014 | 01:08 AM
Christian95
Started her up and didn't see any from rear gasket but the front had fresh oil on it. I wouldn't think the front could leak all the way back but I can't see any other leak
Old Apr 29, 2014 | 01:22 AM
lt4obsesses's Avatar
lt4obsesses
Not sure how yours is set up, but on the LTx motors, there's an oil pressure switch/sending unit assmebly on the rear of the engine that has been known to leak. Oil dripping onto exhaust manifolds would explain the smoke.
That or the rear seal of the intake manifold, as others have suggested.
Old Apr 29, 2014 | 01:30 AM
Christian95
nothing on the oil sender. I checked that first assuming it was the culprit but no oil. Can't see any on the rear intake either. I might just have to take my distributor cap off to see better
To Blown headgasket??
Old Apr 29, 2014 | 02:09 PM
Christian95
After some more digging I noticed my oil flute is loose and will just come right out. Cold start I have close to if not 80 psi and 60 after warming and it's pegs when I rev it. So with this much pressure I would imagine oil is spraying all over down there. Makes me wonder though, why is my pressure so high?
Old Apr 29, 2014 | 03:11 PM
DanielRicany
The more pressure the better! 80 isn't too high. Mine is like 60 or 70 on a cold start.
Old Apr 29, 2014 | 03:20 PM
Christian95
Good to know. Guess I'm just not used to the high pressure. I found a house that goes to my throttle body from the vac system and it was unplugged. Also there's a hose the goes from the passenger valve cover to the throttle body and it has oil inside of the hose. What are these hoses?
