A/C makes car die
Old Apr 30, 2014 | 07:40 PM
nebraska93's Avatar
nebraska93
6th Gear
Default A/C makes car die
I have a 93, after starting it idles and run fine until I turn on the a/c compressor at which time the idle drops and the car dies. I've replaced the distr, the coil, plugs, Throttle position sensor. Any ideas?
Old Apr 30, 2014 | 09:38 PM
SunCr's Avatar
SunCr
Usually one of two causes: The ECM receives a signal to bump up idle from the A/C Programmer a nano second before it drives the Compressor Relay. Lose the signal or if the ECM doesn't recognize it, it stalls. You need a Scanner to diagnose what it is - Progammer or ECM. The other cause is a crapped out compressor - the ECM can only do so much. Remove the belt and make sure you can turn the outer hub of the compressor by hand. If not, it's shot and needs to be replaced.
