fan wire?
Old May 2, 2014 | 06:46 PM
rochhound's Avatar
rochhound
Default fan wire?
i just got my 86 running fresh motor i have no history with this car.
i have a single blade plug coming from the fan and cant figure out where it should go its located near the ac comp also still not sure where relays are located under hood heres apic
any help appreciated
steve
Old May 2, 2014 | 07:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That pic is a little "close" and blury to get a mental image but the main fan relay is located on the LH fender well below the brake MC.
On my '88 the coolant fan power wire is Blk/Red and the ground wire is Blk.
Old May 2, 2014 | 08:17 PM
vetteoz's Avatar
vetteoz
Stock there is no wire from the fan motor direct to a sensor ; power only comes from the mentioned relay
unless a PO has ired the main fan to run of the mech sensor used for the Aux fan
Old May 2, 2014 | 08:46 PM
rochhound's Avatar
rochhound
theres three wires coming from fan
blk/purple
black grnd
green
the green is split one to relay and one to this plug
the fan runs when jumpered + blk/plp to power but does not engage at 220f
Old May 2, 2014 | 09:09 PM
vetteoz's Avatar
vetteoz
blk/purple
black grnd
green
The stock fan only as 2 wires as shown above
What happens when you ground the sensor?
Old May 2, 2014 | 09:27 PM
rochhound's Avatar
rochhound
the pic i showed is the radiator water level sensor!
i havent chased down the sensor yet i think its located under the plenum check tomorrow
thanks for the help
steve
Old May 2, 2014 | 10:17 PM
vetteoz's Avatar
vetteoz
Sensor that location is the IAT sensor.
Any coolant sensors / switches fit in the heads
If you have a single fan there is no switch for the fan ; control is solely from the ECM which stock turns fan on at 228F
Old May 2, 2014 | 10:54 PM
rochhound's Avatar
rochhound
thanks so much will attack tomorrow
steve
Old May 3, 2014 | 01:21 AM
Cliff Harris's Avatar
Cliff Harris
That's the low coolant sensor. It goes into the passenger side radiator tank:
Old May 3, 2014 | 10:08 PM
rochhound's Avatar
rochhound
ive chased down my fan relay and grounded the green/wht and the fan comes on according to the schematic that gos to the emc my question is how does the ecm no to close circut
and turn the fan on. heat sensor or? im going up to 335 f the fan does not come on.
thanks for the help
Old May 4, 2014 | 04:15 PM
65Z01's Avatar
65Z01
The coolant temp sensor for the ECM is in the front of the intake base below the TB. There should be a Yel & a Blk wire.
To see if the ECM drivers can engage and hold the fan relay on, open the small connector in the A/C pressure line and start the engine; the main fan should come on and stay on.
Old May 4, 2014 | 07:13 PM
vetteoz's Avatar
vetteoz
I would be checking your temp gauge operation
Old May 4, 2014 | 07:16 PM
vetteoz's Avatar
vetteoz
Or jumper A-B at the ALDL connector and turn the key on.
Fan should run
To fan wire?
