Big brake upgrade
Old Jul 20, 2002 | 12:30 AM
GS 163's Avatar
GS 163
Default Big brake upgrade
Im thinking of going with some bigger brakes. I would like to get some Z06 calipers and 13" rotors. My question is does anyone sell this as a package deal, if so, who? If not, what is all involved in going with the bigger brakes and C5 calipers? Also, what would the ballpark figure be too? Figure I will put ss brake lines in while Im at it, also want some cross drilled rotors. thanks for the help.
JP
Old Jul 20, 2002 | 01:33 AM
vader86's Avatar
vader86
Default Re: Big brake upgrade (JPLT1)
i know Vettebrakes & Products sells a C5 conversion for about $750
Old Jul 20, 2002 | 11:10 AM
GS 163's Avatar
GS 163
Default Re: Big brake upgrade (vader86)
I have seen that kit. I dont think they come with the rear calipers and rotors though. Anyone else some insight on this subject.
Old Jul 20, 2002 | 12:02 PM
John Row's Avatar
John Row
Your rear brakes are fine, unless you are into serious racing. The rears are only doing something like 20-25% of the braking. If that's the case then just move your fronts to the back and use good pads. You'll loose the parking brake, but a race car doesn't need one.
Someone check me, but I think you'll need the ZR1 wheels for the Z06 setup. The Z06 is much better than the GS upgrade and the Z06 rotors are about 50% cheaper.
Here's some info on the GS upgrade:
www.superchevyperformance.com/misc/gsbrakes.asp
[Modified by John Row, 10:05 AM 7/20/2002]
Old Jul 20, 2002 | 01:21 PM
RonRed89's Avatar
RonRed89
Default Re: Big brake upgrade (John Row)
It should work fine with the Grand Sport wheels that he has on the car now. Jeff Kopp (18carfan) has a web page outlining the parts you'd need to buy if you wanted to buy them separately. That page is http://www.superchevyperformance.com/c5brakes.html. You might consider this if you didn't want the particular rotors in the kit and wanted to upgrade them to a Baer Eradispeed or equivelant.
Hope this helps out.
Ron
Old Jul 21, 2002 | 11:15 AM
GS 163's Avatar
GS 163
Default Re: Big brake upgrade (RonRed89)
Old Jul 21, 2002 | 08:07 PM
R23HTC's Avatar
R23HTC
Ron
Jeff recently changed the addresses on the GS and C5 brake upgrade sites. The GS is one is correct:
http://www.superchevyperformance.com/misc/gsbrakes.asp
This is the new one for C5 brakes:
http://www.superchevyperformance.com/misc/c5brakes.asp
Old Jul 21, 2002 | 09:35 PM
2012 coupe's Avatar
2012 coupe
Here is how I upgraded my 1992 Brakes. ($115 each).
Bought GS front calipers, (TLD) and S/S brake lines. (??)
Bought Power Slot rotors for all . ($400)
Added good brake pads.
They work great and do not fad anymore.
:flag
Old Jul 21, 2002 | 09:39 PM
GS 163's Avatar
GS 163
Default Re: Big brake upgrade (R94 LT 1)
Thanks R94. :)
Old Jul 21, 2002 | 09:56 PM
R23HTC's Avatar
R23HTC
Thanks R94. :)
NP :cheers:
Old Jul 22, 2002 | 12:35 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
They don't JP. Just the fronts. Was just there talking with them last week.
Gordon-Tampa :cheers: :seeya :flag
Old Jul 22, 2002 | 01:47 AM
RonRed89's Avatar
RonRed89
Thanks for the update. I'll keep a note of those.
I heard that Racing Dynamics (or whoever is currently making the adapters) is coming out with an adapter to put the Porsche Big Red brakes on the C4s as well. This would an even cooler upgrade as the Porsche Reds are really Brembos at half the cost.
Old Jul 22, 2002 | 07:38 AM
R23HTC's Avatar
R23HTC
If I ever get another set of wheels, I'll probably go with the C5 ZO6 red brakes. :yesnod:
[Modified by R94 LT 1, 5:39 AM 7/22/2002]
Old Jul 22, 2002 | 08:25 AM
GS 163's Avatar
GS 163
Thats what I want with some eradispeed rotors.:)
Old Jul 22, 2002 | 06:10 PM
gene284's Avatar
gene284
Electro-Dynamics Brakes is where the C5 brake adapters for the C4's are.
They have the engineering almost completed on the Porsche Turbo caliper and rotor upgrade for the C4's.
[Modified by gene284, 5:18 PM 7/22/2002]
Old Jul 23, 2002 | 12:07 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Big brake upgrade (gene284)
To Big brake upgrade
