Low Oil Press @ Idle
Old May 5, 2014 | 12:03 AM
Lrod's Avatar
Lrod
Default Low Oil Press @ Idle
Just drove my car after having it sit for a long while, had to get some new cats and 02 sensors for it to pass. Problem is that at idle it has very low oil press, as it accelerate it picks up. I haven't changed the oil in sometime, any ideas??
Old May 5, 2014 | 12:12 AM
93VettePilot's Avatar
93VettePilot
Pretty normal on these cars especially with warm engine and 5w30(thin). Cold engine oil pressures should be noticably higher. Dash guage is notoriously inaccurate. Better to check it at the sender port with a hand held pressure guage. 10 psi at a 1000 rpm is adequate for a stock small block. Small block oil system is usually pretty bulletproof.
