What is proper 0-2 sensor voltage?
Old Jul 20, 2002 | 02:32 PM
MagRed_04's Avatar
MagRed_04
Default What is proper 0-2 sensor voltage?
What should the 0-2 sensor be reading in mv when the car is warm and in closed loop mode? I am getting around 720mv... is this normal?
Old Jul 20, 2002 | 03:21 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: What is proper 0-2 sensor voltage? (Vette_Crazy)
Maybe this will help? Reference 1992 GM ser. man. , When the air/fuel ratio is correct the ECM see's 450 mV . Also low voltage output = lean mixture , high voltage (above 600)= rich mixture with good sensor. If your not seeing black smoke out the pipes and the plugs look good I would guess the sensors bad. Good Luck :D :flag
Old Jul 20, 2002 | 03:41 PM
jtjerry's Avatar
jtjerry
Default Re: What is proper 0-2 sensor voltage? (C4Crazy787)
at idle it should read from 0.1 to 0.9 v and back to 0.1 and so on.
at wot about 0.85 v steady
Jerry
To What is proper 0-2 sensor voltage?
