AC delete on 89
Old May 8, 2014 | 06:20 AM
Jay Detwiler's Avatar
Jay Detwiler
2nd Gear
Default AC delete on 89
Just want to add AC delete name and part # to make it easier for others that want to do this. 98 chevy s-10 delete pulley will work. The one I got was a Dorman #34174. You need to put the 2 sensors back on wireing harness by the oil dip stick if you take that pipe out or your fan will run all the time. Also have to ream the rear bolt hole out on the delete bracket for it too fit. It uses same belt.
Old May 8, 2014 | 07:34 AM
vetteoz's Avatar
vetteoz
Originally Posted by Jay Detwiler
You need to put the 2 sensors back on wireing harnessor your fan will run all the time.
Or jumper the connector
