Vacuum hose
Old May 9, 2014 | 09:15 AM
Charles.rogers1's Avatar
Charles.rogers1
Default Vacuum hose
Looking for an alternative vacuum hose that runs from the intake to the fuel pressure regulator. It is a short plastic like line that runs right across the top of the intake. I would like to find something that can run all the way around the back of the intake so I can use my valve covers without having to cut holes though them for this one stupid little line.
Thanks!
Charles R
Old May 10, 2014 | 02:43 AM
Cliff Harris's Avatar
Cliff Harris
What year is the car? I assume LT1 from your description.
You can buy the plastic vacuum line in 3 foot lengths at any auto parts store...
Old May 11, 2014 | 11:06 AM
Charles.rogers1
yea sorry always forget to put the info on the car.. its a 96 lt1
Old May 11, 2014 | 11:07 AM
Charles.rogers1
and does it have to be plastic? like as long as it is the same diameter could it be a rubber hose or does it need to be plastic to keep vacuum the same or anything
Old May 12, 2014 | 02:52 AM
Cliff Harris
I don't think the vacuum cares. I guess you could stick together some soda straws if you wanted to... ;-)
Some people just run rubber hose and leave out the plastic.
It's your car -- do whatever you like.
To Vacuum hose
