84 crossfire mod help
Old May 9, 2014 | 11:30 AM
84vete's Avatar
84vete
Default 84 crossfire mod help
i am looking to boost my performance on my stock 84 engine. i know about the 85 fuel pump but need to know where to do the fuel regulator on the rear tb. how much would it cost to port the intake and any other parts you recommend like cam and gears
Old May 9, 2014 | 03:24 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I'll bet there are some good Performance Shops in Indianapolis! How much money are you ready to spend?
Old May 9, 2014 | 04:08 PM
corvettenorway's Avatar
corvettenorway
First : port manifol , better fuel pump, 10 deg.timing ,1,6 rr, better cat back, kn filter, air mod , headers and do a full tune ! ........... not happy then get a new cam and better heads , ( PICS. OF A PORTED MANIFOIL IN MY ALBUM )
Old May 9, 2014 | 04:31 PM
corvettenorway
Fuel regulator ? Easy to weld a meter on the tube from rear to front tb !
Old May 9, 2014 | 08:12 PM
84vete's Avatar
84vete
When i bought it for 4g from a family friend who has some pretty fast cars said it was fully tuned up and then it sat for 2 years before i got it ive already changed spark plugs and distributor cap and rotor, in the process of rebuilding my tbs i just need to buy the sensors, do you know where i could get the spring in the fuel pressure regulator if it needs to be replaced.
Old May 9, 2014 | 11:38 PM
84vete's Avatar
84vete
Just wondering how to adjust the fuel pressure when i take the tbs apart
Old May 10, 2014 | 04:51 AM
corvettenorway
More pressure on the spring = More fuel
Old May 10, 2014 | 05:45 AM
corvettenorway
No need to replace the spring ! But weld in a meter to se the pressure !
Old May 10, 2014 | 10:59 AM
84vete's Avatar
84vete
I dont have a welder handy anything else i could do step by step instructions? Could i take it to someone maybe?
Old May 10, 2014 | 11:05 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Some great tips here
http://forums.corvetteforum.com/c3-t...solutions.html
My ported CFI Intake on my 82
Old May 10, 2014 | 11:30 AM
corvettenorway
Nice
Old May 10, 2014 | 11:33 AM
corvettenorway
By one ( or take it to someone , yes )
Old May 10, 2014 | 11:59 AM
84vete's Avatar
84vete
Thanks guys will do all that and see how it goes
Old May 10, 2014 | 12:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You don't need to weld on a pressure gauge. That is a nice/handy mod, but not necessary. Between the passenger's side frame rail and the engine, there is a rubber line for the fuel. "T" into that line (or make a temp replacement w/a "T" in it. Attache your pressure gauge there.
The new fuel pump won't change the fuel pressure (unless your stock pump couldn't meet demand anymore). The regulator is what controls pressure. Turn the adjusting screw on the bottom of the regulator CCW to increase pressure.
Old May 10, 2014 | 12:59 PM
ToniJ1960's Avatar
ToniJ1960
Whats the correct or `best` pressure for most crossfire systems?
Old May 10, 2014 | 01:24 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
12-13 psi. If I'm wrong someone will correct me
From the link above post.
...82 pump pushes volume of 9-13 psi. The engine likes around 12. The pressure is set by the regulator spring in the driver side TBI. Under load (or as the pump weakens) the volume starts to drop, fuel supply is not enough to keep up with the RPM's. Once it drops below 9 psi the motor starts to hesitate and loss power at higher RPM.
...The 85 pump pushes volume at 40 psi. Well above the 12 psi the spring is set at. The spring will step down the volume to 12 easily. And because the 85 pump is so far above the 12 your TBI's will always get 12. A weakening 85 pump has a long way to go before it can not deliver enough. The other advantage is you can pop the cap on the regulator spring and dial it up a bit. Some have gone as high as 14-15 psi."
Old May 10, 2014 | 01:40 PM
corvettenorway
14 psi on my car !
To 84 crossfire mod help
Old May 10, 2014 | 01:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Stock pressure pretty typically seems to be too low...generally they seem to like a little more than the the factory 9-13 PSI, but "Feed it what it wants!"
Old May 10, 2014 | 11:59 PM
84vete's Avatar
84vete
Weird clicking noise in the driver's side rear wheel when i go over bumps or take off slow or stop idk what it is, differential is making bad clunking noise when the car shifts (automatic trans)
Old May 12, 2014 | 12:08 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Check your U-joints, C-beam bolts. Rear tie rods.
