'91 Air Conditioning question
Old Jul 20, 2002 | 10:04 PM
csapow's Avatar
csapow
Default '91 Air Conditioning question
The compressor will not operate with the dash switch. I vacuumed the system and weighed in refrigerant. I had to run 12 volts to the compressor to get it to take the charge. I have 12 volts at the low presure switch on the low side. I do not have voltage at the two switches in the high side line. What are the two switches in the high side? Any sugestions where to start looking for a problem?
Old Jul 21, 2002 | 02:12 AM
cesar's Avatar
cesar
Default Re: '91 Air Conditioning question (csapow)
disconnet the batt for about 30 minutes to reset the computer if you have the electronic control
Old Jul 21, 2002 | 04:03 PM
csapow's Avatar
csapow
Default Re: '91 Air Conditioning question (cesar)
Thanks, I'll try that.
Old Jul 21, 2002 | 09:45 PM
csapow's Avatar
csapow
Thanks Cesar, I disconnected the battery for 30 minutes and after reconnecting the battery the a/c worked.
To '91 Air Conditioning question
