Vacume leak, or something else?
Old May 13, 2014 | 11:17 PM
Michael S's Avatar
Michael S
Default Vacume leak, or something else?
OK, I'm starting a different thread to get info about this aspect of my engine.
Idle has been tolerable, but not right. Much better than when i got it, but I'm trying to make it better and smoother.
I put a vacuum gauge on the manifold and I'm only getting 15" of vacuum, with a shaky needle.
On my gauge it says the timing is late. but I've set the timing with my new balancer.
what do y'all think?
I've sprayed carb cleaner all around. vacuum hoses are new.
what else to check?
Trying to figure out what to look into.
Old May 14, 2014 | 01:39 AM
hooked073's Avatar
hooked073
with a shacky needle do you mean it bounces lets say from 15 to 12 bach and forth? If that is what you are saying that is usally a sign of valve train problems
Old May 14, 2014 | 05:43 AM
Michael S's Avatar
Michael S
I just went out and looked at the gauge again to make sure. I was incorrect in how much movement the needle has.
It's less than one inch of vacuum either way. So basically it's just a about a 1/2" of vacuum either w needle, not the steady vacuum that I get when I put the gauge on the vacuum port on the throttle bodies.
Old May 14, 2014 | 07:35 PM
jv9999's Avatar
jv9999
Not sure if this helps, but I had a similar problem. Tried the carb cleaner and propane tricks to no avail. Finally I sprayed water on the intake and I could see the water being sucked in. New gaskets and now a steady 20 inches.
To Vacume leak, or something else?
