Interior lights staying on.
Old May 18, 2014 | 08:58 AM
skullrider67's Avatar
skullrider67
5th Gear
Default Interior lights staying on.
Can someone give me any help, I own a 92 C4 and my interior lights come on when you open the doors but then don't go out for 20 min. Any ideas.
Old May 18, 2014 | 03:02 PM
HlhnEast's Avatar
HlhnEast
Its probly the delay timer. It is a small white box looking affair with several white (?) wires and is located behind the breadbox on a 85 but not sure about the later models, Replacements are available or you can eliminate it altogether if you want. Search "delay timer" in the C4 specific forum and see what pops up.
Old May 18, 2014 | 04:53 PM
skullrider67
5th Gear
Thank you for the insite. Now I just have to find it.
Old May 19, 2014 | 03:17 AM
Cliff Harris's Avatar
Cliff Harris
Check this thread for the solution to this problem:
http://forums.corvetteforum.com/c4-t...off-fixed.html
Old May 19, 2014 | 05:21 AM
HlhnEast's Avatar
HlhnEast
Try this first but if it doesnt work, investigate further. The "key" here is his lights do go off after a while. Could be it takes some time to jiggle back straight.
To Interior lights staying on.
