Coolant loss
Old May 19, 2014 | 03:04 PM
Pres712's Avatar
Pres712
Default Coolant loss
About once a week I have to add coolant. Today I rented a pressure tester, pumped it up to the required lbs. and it held. There is no water in the oil so I guess that means it's getting into the engine somewhere? My question is before I tear it down, would a stop-leak in the raditor work? If it's a gasket would that seal it? I know I'm just woofing myself but it's worth a try?
Old May 19, 2014 | 03:20 PM
BOOT77's Avatar
BOOT77
How much are you adding? Any smoke from the exhaust?
Old May 19, 2014 | 03:31 PM
Pres712's Avatar
Pres712
About a pint a week and no smoke.
Old May 19, 2014 | 03:37 PM
John A. Marker's Avatar
John A. Marker
It could be the early stages of a blown head gasket. Suggest you pull plugs #7 and #8. These are the cylinders with a higher gasket failure rate than others. If one looks very clean compared to the other....chances are it is the head gasket. It will get worse over time if it is.
Old May 19, 2014 | 07:03 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default recovery tank
Where are you adding the coolant, the recovery tank because it is low or removing the radiator cap to check coolant?
A normal system will discharge coolant from a full engine/radiator into the recovery tank during substained driving and with overnight cooling and not being driven the coolant will be pulled back into the radiator.
Old May 19, 2014 | 08:46 PM
hcbph's Avatar
hcbph
First thing I'd do is put some paper under the car after it's been driven and see if anything gets wet over night. After sticking the paper under it, while it's still running, lift the hood and look for any wisps, though I doubt any with the little you're losing.
Another area some have had issues with is the heater core. Check around it for wetness. Maybe run the defroster and see if anything shows up on the windshield.
Unless it's new, I would change the radiator cap anyway. I had one that would hold pressure but wouldn't hold the seal to suck the coolant back from the reservoir as it cooled.
Old May 19, 2014 | 10:48 PM
Oldtimah's Avatar
Oldtimah
I had a similar problem with an '85. I bought it from a fellow who complained that it overheated around town. When I got it home I checked the radiator, and it was empty, so I filled it. Car ran fine. I checked the level in the radiator after a while (Days) and the coolant was a little low. I figured I hadn't gotten it full the first time and so I topped it off. A couple of weeks later and it was down a little, so I started checking things, to no avail.
Then one day I noticed a thin trickle of coolant at the rear of the block on the pass side. I called a friend who was "the man' at the largest Chevy dealer in LV. He said they all do that, Alum head, steel block. I asked how much to fix, he said "$30 for gaskets, $1000 or more for labor, cuz you have to take the whole top of the engine off". He talked me into doing it, and it was a bitch. But I got'er done, and all was forgiven.
The other problems I had with the coolant in this car was 1) replaced thermostat witha 180 Robertshaw, and 2) pitched the radiator cap in the bushes and bought the correct one from GM. 25,000 miles later and no problem.
I don't know if any of this will help,but it's the simple things that can hurt you!
Old May 20, 2014 | 07:21 AM
Pres712's Avatar
Pres712
Thanks for all the suggestions. I had a hydro lock a few years back and after pulling the plugs saw liquid run out of one of the plugs. Sure enough it was a blown head gasket. And you are right it was over $1,200 to fix it. I've replaced the cap, pulled the overflo tank and cleaned it. The tank stays full but I still need to fill into the raditor; so why doesn't it pull from the overflo tank? Maybe the new cap is bad? I'm going to pull the plugs and take a look. Again, thanks...
Old May 21, 2014 | 06:25 AM
kenmohr's Avatar
kenmohr
Have the cap tested. Just had similar problem and cap was bad.
Old May 21, 2014 | 07:25 AM
Pres712's Avatar
Pres712
Bought a new cap, will try it today.
Old May 21, 2014 | 07:41 AM
AirForceOne!'s Avatar
AirForceOne!
Me too and it was the cap! Make sure you get a good cap and not a cheap one!
Old May 21, 2014 | 10:40 AM
Pres712's Avatar
Pres712
What's everyones opinion on a "stop leak" product?
Old May 21, 2014 | 10:51 AM
Kmcoldcars's Avatar
Kmcoldcars
I would not use one unless there was no other choice. I have used them on cheap cars that it was not worth replacing the radiator and they worked.
If your radiator is losing water but the overflow stays full you may want to check the line between the radiator and the overflow as they sometimes get plugged with junk and there is no water movement through the line. Check the radiator cap. Check around the radiator cap for cracks in the radiator.
Old May 21, 2014 | 12:54 PM
70ZZ3 96LT4
Default 1985 Corvette
1985 Corvettes did not leave the factory with aluminum heads. As per your friend's information they all do that, wonder when my 1985 Corvette is going to do it. 106,000 on my 1985 with cast iron heads and no leaks, and my original owner 1996 LT4 Corvette with aluminum heads does not leak.
To Coolant loss
