What size speakers for 89 dash pad?
Old May 20, 2014 | 03:19 PM
WW7's Avatar
WW7
Default What size speakers for 89 dash pad?
Does anyone know what "size" or "brand" of speaker fits in the dash pad on my 89.. I bought another dash pad and it doesn't have speaker mounts , I'll have to use the ones from the old dash pad and I want to purchase the speakers before I remove the pad....Thanks.....WW
Old May 20, 2014 | 04:19 PM
engle1147's Avatar
engle1147
http://www.amazon.com/Corvette-Central-1978-1989-Dash-Speaker/dp/B0034EC23W http://www.amazon.com/Corvette-Central-1978-1989-Dash-Speaker/dp/B0034EC23W
Old May 21, 2014 | 03:39 AM
Cliff Harris's Avatar
Cliff Harris
Since my dash pad is out right now and I have the Delco radio...
I measured the cone at 4" x 5-1/2". I guess that would be 4 x 6.
Old May 21, 2014 | 06:22 AM
WVZR-1's Avatar
WVZR-1
They are 4 X 6 and depending on the radio used the 10 Ohm might be of some concern. The OE weren't discontinued until recently and there could be some OE out there by part # on eBay or whatever. These did fit nearly everything GM did for a couple decades so ..
Last GM # 16033662
Old May 21, 2014 | 07:04 AM
WW7's Avatar
WW7
Thanks for the replys.. I have an Alpine system so any good 4X6 should work.....WW
Old May 21, 2014 | 04:35 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Wayne, Try to get the shallowest speakers you can find. The OEM speakers were very shallow. Most aftermarket speakers would be so deep that getting the dash pad back on becomes difficult.
Old May 21, 2014 | 07:59 PM
GKK's Avatar
GKK
Or, you'll have to cut some of the inner dash plastic.
Old May 23, 2014 | 01:21 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Or, convert the grilles to drop-ins -- like I did. I bought some of those standard speaker "pins" that hold speaker grills on home speakers. I put them on the dash grills.
Now I can pop them out first, then r/r the dash pad.
But, there IS a limit to the 4x6" speaker depth. I'm thinking 3" maybe. But, I don't remember for sure.
Unless someone posts that depth, I would pull the dash first. It's VERY easy to place back into the car w/o using fasteners. I lived with it "loose" for a few weeks one time. It stays tight....just by pressure.
To What size speakers for 89 dash pad?
