Bearing Torque Specs
Old May 20, 2014 | 08:13 PM
Sean Brian Kirby's Avatar
Sean Brian Kirby
Default Bearing Torque Specs
Hi! Have yet another question for you enormously helpful folks. We'll be torquing down the 36mm nut and Torx bolts on the bearings tomorrow. We were all kinds of confused. I'd seen a guy say 187 lb-ft for the 36mm nut; Dad swore he saw a video where a guy said 164. Our confusion ended... when I read someone saying it's 164 original factory spec, 200 for current (revised, I suppose) recommended spec... and he kinda split the difference and went with 175. What do y'all recommend, and why? While we're at it... to what torque measurement are we torquing down the Torx fittings? As always, many thanks in advance.
Old May 21, 2014 | 06:59 AM
hcbph's Avatar
hcbph
Default Torque
I just did my u-joints on the half shafts about a month ago. The 160+ was in the manual but I've also read where it's been updated to 200.
I did mine just under 200, figuring it was close enough. If there isn't enough torque on the nut, I'm guessing the wheel assemblies would sway side-to-side and eventually separate in some way shape or form.
I've only put a couple hundred miles on it since doing the work but it seems solid.
Hope that helps.
Old May 21, 2014 | 07:28 AM
WW7's Avatar
WW7
This is from my online repair site...WW
To install rear wheel bearing:
10.Inspect the wheel hub and bearing seal, replace if necessary. Also inspect the wheel spindle washer and replace, if damaged or excessively worn.
11.Install the wheel hub and bearing, caliper mounting plate and the wheel spindle washer. The washer flat should firmly seat against the shoulder of the wheel spindle. The lip of the washer should face the wheel spindle splines prior to hub and bearing installation.
12.Install the wheel hub mounting bolts and tighten to 66 ft. lbs. (90 Nm).
13.Install the washer and spindle nut, and hand-tighten.
14.Install the wheel retainer and a new cotter pin.
15.If removed, connect the transverse spring to the knuckle.
16.Install the brake rotor, then install the caliper and parking brake assembly.
17.With an assistant depressing the brake pedal to prevent the wheel from turning, tighten the spindle nut to 164 ft. lbs. (223 Nm). The vehicle should not rest on the tires or move until the spindle nut is tightened.
Fig. 11: With an assistant depressing the brake pedal, tighten the hub nut to specifications
Old May 21, 2014 | 07:41 AM
WVZR-1's Avatar
WVZR-1
The 3 hub mounting bolts in the FSM's is 66 lb ft depending on the year. I believe the 66 lb ft is fine. Regarding the 36mm spindle nut, I've never seen the 200 number in print or in a GM TSB so until someone could "show me" I'd say that was pulled from someone's a$$.
The number for the 88+ spindle nut is I believe published at 164 lb ft
In an early FSM (1984) the spindle nut is mentioned at 151 - 177 lb ft and the hub bolts at 59 - 73 lb ft.
Ironically maybe but take the average of the 151 & 177 and the 164 result is maybe what they determined they would publish later. The hub bolt average 59 & 73 is also the published number for the later hub bolts. Coincidence? I'd think NOT!
"your" online repair site? That's quite an "adventure" I'm sure!
Old May 21, 2014 | 08:02 AM
WW7's Avatar
WW7
I didn't mean it's "mine".....I just use it......The repair site is from the Allegheny County Library system in Maryland, and is free for anyone living in the area.. Since you live fairly close to me you may give it a try, maybe you can access "my" online repair site also.......:The 66 lb ft spec is for the OPs 86 Corvette........WW
Old May 21, 2014 | 08:26 AM
Aardwolf's Avatar
Aardwolf
I go through a lot of wheel bearings racing the car and some come NIB with an attention sheet saying in red "TQ nut to 200 ft/lbs".
Old May 21, 2014 | 10:54 AM
TimV SR's Avatar
TimV SR
Do a search here and you will find many who say Gordan Kilebrew recommends 200 Ft/lbs on the spindle nut. This is updated from the original number in the FSM.
If you are using the HD tapered bearings from WBI, use thier number. Thier bearings are preloaded by the spindle nut @ 180 Ft/lbs.
You also want to know about the thin teflon-coated washer that goes on the spindle behind the bearing assy. Many here say to replace it everytime. The last time I did one of mine, the washer was there and looked good, so I reused it even though I have new ones. The main thing is to replace it if yours is missing.
Old May 21, 2014 | 11:32 AM
hcbph's Avatar
hcbph
Default Teflon washer
When I did the u-joints on my 86, part of the reason was I was getting noise out of the rear. I pulled the half-shafts and spindle out as a unit. Being the washer was looking me in the face in addition to the u-joints, I couldn't see anything obviously wrong with the teflon washers but I replaced them anyway. I didn't want to have to tear it down again if the noise remained after doing the u-joints, so for around $16 more, I changed those washers too.
The u-joints were definitely bad and not sure of the teflon washers, but with all of them changed (u-joints and teflon washers), the noise is gone and that's what I wanted so it was a drop in the bucket for me additional to be rid of the noise. I want to drive rather than lay under the car.
When I loosened or tightened the spindle nut, with everything else hooked up, I just set the parking brake and it worked fine for me. The car was on jackstands in back plus a jack under the batwing plus the front wheels solidly blocked, and didn't move an ounce while loosening or tightening the spindle nuts.
Old Aug 16, 2014 | 09:26 AM
Sean Brian Kirby
Thank you all for your answers. We got the hubs in without a hitch - though it was by no means easy. (Dad thought the water pump was harder. Now we're installing a later power window regulator in the driver's side door; the ribbon broke.) Apologies for the late thank you. This is a great forum...
To Bearing Torque Specs
