My original problem with my 1995 vette was when it was cold it would tend to idle down a lot when it was cold, and worse when i turned on the ac. Well I cleaned it and it helped a lot and it only did it when i turned on the ac. After it's fully warmed up I don't really have a problem with it. SO since the problem was still there I purchased a new IAC motor and put it on yesterday. Same problem. I did the little reset procedure where you press the pedal and start and all that and it's STILL present. This is especially bad since it's a stick. This car is stressing me out. What should I do?
.with a new Iac...i think you should do the min idle adj....it's done with the iac disconnected...make sure it's in time....but....the ecm should turn up the idle with the a/c on...also fans....you may have another issue...good luck....paul
so you're saying I need to do the above procedure i talked about with the iac disconnected?? and then what? do i reconnect it when it's running or what?
no, not the first procedure....you need to do the minimum idle adjustment...there are threads on this forum on the procedure if you do not have a factory manual....sounds liike you will need one....we all do..
if you're going to be tinkering....it's a easy procedure, just follow the steps...the IaC gets disconnected during this procedure...Paul
Is this it?
1) With the engine off, ground the diagnostic terminal of the ALCL under the dash.
2) Turn on the ignition to ON but do not start the engine....wait at least 30 seconds.
3) With the ignition still on, disconnect the IAC electrical connector.
4) Remove the ground from the diagnostic terminal of the ALCL and start the engine.
5) Assuming you did not have to adjust the idle RPM's.....turn the ignition to OFF and reconnect the IAC valve connector.
is this something I can do with the paper clip I hear works? if so, how?
should I leave the ac off or on?
Is this it?
paper clip works fine.. stick it in a & b...1st two on the left......there are a few more steps....adjust idle in drive...put parking brake on my 85 should be set to 450...recent update says set at 500 rpm...then reconnect the Iac... leave the a/c off...some manuals say disconnect the distributor wire also so the ecm doesn't try to change the timing while you're doing it.. make sure your timing is set and the tps is correct before setting the min idle...paul
my car is a stick with a lt1 and a good cam and everything and it likes at least 1000 rpm
ok i have a 16 pin connector...what am i supposed to connect my paper clip to?? I've looked but there's no clear word on it. will this even work for me dude?
There is a pressure switch on one of the AC lines that tells the PCM that the compressor is running. The PCM will increase the idle speed to compensate for the extra load of the AC compressor. That switch (or the associated wiring/connectors) could be bad.
Disclaimer: Things changed a lot over the years and your car may not have that switch. If not, then it must use some other method to tell when the AC is on and increase the idle speed.
I can rule out the TPS. When I disconnected it the problem is still there. Push the ac button and that idle DROPS. Again, this problem is still there with the ac off. I go to take off from a stop and it stumbles because of this. it doesn't even register the throttle much so i have to raise the rpms with the clutch pedal pressed and then release it just to go. whatever it is it's also affecting my mpg. i tried a smoke test for vacuum leaks and found nothing. MAF has already been cleaned as well as the air filter.
please help my last resort is a mechanic. :\
My mechanic was here yesterday. We hooked up the pressure controls and went for a drive and we are blown away that the compressor keeps going off when we takeoff to drive but when we slow down and sit at a light, it turns back on.
I took the new climate control module that I bought and sent it to Batee .com to be rebuilt. When that comes back, we will see what happens. Definitely can’t figure this out.
