Problems with Keyless Entry, please help
Old May 30, 2014 | 03:34 AM
Decat's Avatar
Decat
Default Problems with Keyless Entry, please help
So I just received a key fob for my '94 C4 and I went to do the programming and it is not working.
-I am hitting the "Trip Odo" button twice and then pressing and holding the "Fuel Info" until the "Passive Keyless Entry" light comes on the dash, and it does. So far so good.....
-However the next step says to turn the key to the off position and the "Passive Keyless Entry" light should start to flash, but this does not happen. The "Passive Keyless Entry" light just stays on. No flashing.
No matter what position the key is in the "Passive Keyless Entry" light will not flash, and therefore will not program my new key fob I just got.
I have already checked the fuses, and I have made sure the key fob is well out of range and inside the house, and nothing is helping. Could there just be too much interference in my neighborhood? I live right in the middle of Houston. I am out of ideas, any help would be greatly appreciated. I have been manually using the key to unlock since November now.
Old May 30, 2014 | 04:24 AM
WVZR-1's Avatar
WVZR-1
This old Tech Tip mentions "NOT FLASHING" but says all worked anyway!
Good Luck!
https://www.corvetteforum.com/techti...=219&TopicID=2
Old May 30, 2014 | 09:21 AM
Hooked on Vettes's Avatar
Hooked on Vettes
When you turn the ignition key to Accessories or Off, the key cylinder engages a mechanical contact switch.
This sends a ground signal to the PKE module which places the PKE module in program mode.
It also sends a ground signal to the CCM. The Chime module should sound if you open the door. This would confirm the Key in the Ignition Switch is working. (This assumes the chime module is working).
Here is a picture of the switch on a non air bag steering column. It's a copper strip of metal that may just need cleaning with a burnishing file.
To access the switch you need to remove the air bag, pull the steering wheel, move the clock spring for the air bag out of the way and the turn signal switch assembly.
Old May 30, 2014 | 11:29 AM
markKlein's Avatar
markKlein
The question is, with the key in the cylinder, does the open door chime sound? If not, you may have a worn cylinder, and the system thinks you have turned the key off and removed it. When you turn the key off try keeping your hand on the key and pushing it in as far as possible. this has worked for some people.
Interference is not the problem, just to be sure I think the fuses are 26, 40 and 42.
Old May 31, 2014 | 12:40 PM
Decat's Avatar
Decat
Chime works perfectly. I will buy a new battery for the Key Fob and try the instructions where the PKE light was not flashing. Thanks for all the responses I really appreciate it. Gives me something to go from.
Old May 31, 2014 | 04:29 PM
Decat's Avatar
Decat
Ok so here is exactly what happens:
I get the Passive Keyless Entry light to come on, then when I turn the key to the off position, the door chime starts sounding and the Passive Keyless Entry light will stay on until I bring the Key Fob within 10 feet and then the PKE light will go out immediately and nothing is programmed.
Old May 31, 2014 | 04:45 PM
Decat's Avatar
Decat
Once I get the PKE light to come on and before turning the key to off, I can get the PKE to go off for an instant randomly by moving the key FOB around. But as soon as I turn the key to the off position the light goes out within a few seconds if the Key Fob is in range.
Old Jun 1, 2014 | 12:01 AM
Hooked on Vettes
When the PKE light comes on solid are you then turning the key to Off or the Lock position? Not sure if it makes a difference but the Service Manual says to turn the key to the Lock position and the PKE light should flash a 1 indicating it's ready for the 1st fob to come in range.
You have 2 minutes to program up to 3 FOB's.
Did you say with the key in the ignition cylinder key in the Lock position if you open a door the Chime sounds?
Old Jun 1, 2014 | 08:58 AM
markKlein's Avatar
markKlein
The chime comes on? You have the door closed, right? Why is the chime coming on?
Old Jun 1, 2014 | 09:02 AM
markKlein's Avatar
markKlein
I'm pretty sure the manual says to turn the key "off". And the light should continuously flash.
Old Jun 1, 2014 | 09:05 AM
markKlein's Avatar
markKlein
One more question, how are you determining that the system is not programmed? Do you understand how to turn the system on/off?
Old Jun 1, 2014 | 02:08 PM
Decat's Avatar
Decat
The fact that the key fob does absolutely nothing. No matter how long I hold any button on the thing nothing the key fob does, whether proximity to car or buttons on the key fob, the car does not respond at all to the key fob in any way.
Old Jun 1, 2014 | 02:10 PM
Decat's Avatar
Decat
Yes I have tried every different position of the key and the light never flashes just stays illuminated until the key fob is in range, then turns the light out immediately. If the key fob is already in range when I try to get into the program mode then the light just stays on.
Old Jun 1, 2014 | 02:12 PM
Decat's Avatar
Decat
I have tried getting into the program mode both with the door shut and open, and it does the same thing, as soon as the key fob is in range it turns the light out. And I still cannot get the light to flash at all.
Old Jun 1, 2014 | 02:16 PM
Decat's Avatar
Decat
Yes. If I open the door, the chime sounds. It's just that the light stays on and never starts flashing, and as soon as a key fob is in range the light goes out. If no key fob comes in range the light will stay on, but not flash. I have tried this in the position between lock and on, I have tried it in the lock position, I have even tried it on the accessory position, and it does the same thing, the PKE light just will not flash at all, and goes out immediately when a key fob is in range. It definitely is receiving a signal because the light goes out in response to the the Key Fob being in range (or putting the battery back in the key fob) immediately, but with no key fob in range the light will stay on, but not flash.
Old Jun 1, 2014 | 02:19 PM
Decat's Avatar
Decat
So is there something in the car like a receiver or wires or anything at all I can check? Is this module or whatever easy to locate and or replace. I feel like I have exhausted all possibilities and I don't feel like my car is possible to program a key fob in its current form. Is there a PKE module?
Old Jun 1, 2014 | 02:36 PM
Hooked on Vettes
The gain access tp the PKE module requires the remove of the dash pad.
The module is behind and above the DIC panel area.
If the car is new to you, have you looked for a key fob under the seats or in the
console?
Trying running the PKE diagnostics. The 16 pin diagnostic connector is located under the dash
above the drivers right knee.
http://forums.corvetteforum.com/1551389270-post4.html
Not only could the PKE module be bad since it's not going into Program mode you
also need to verify the new key fob is good.
Some AutoZones have a key fob tester.
To Problems with Keyless Entry, please help
Old Jun 2, 2014 | 08:58 AM
jrcraig1's Avatar
jrcraig1
6th Gear
Default Same Problem on 1996
I just purchased a C4 1996 with less than 15,000 miles on it and I am having the same problem! Have you found a fix yet?
Old Jun 2, 2014 | 03:17 PM
Decat's Avatar
Decat
No I have not. I still need to try and get into the diagnostics test, but I am unsure which pin is 1, basically which way the numbers start on the connector.
Old Jun 2, 2014 | 03:33 PM
WVZR-1's Avatar
WVZR-1
The connector is tapered and 1 - 8 are on the top left to right at the widest aspect of the connector.
'94+ ALDL connector is in this how to that doesn't cover PKE but it's a good read and the image will square you away:
http://tech.corvettecentral.com/2011...trouble-codes/
Pay no attention to the jumper!
