fuel problem
Old May 30, 2014 | 10:24 PM
bug6971's Avatar
bug6971
3rd Gear
Default fuel problem
ok i installed new pump new filter..no fuel pressure past FPR..any idea? will FPR stop fuel flow all together? any help would be greatly appreciated..
Old May 30, 2014 | 11:17 PM
John A. Marker's Avatar
John A. Marker
Do you have pressure at the rail? What is the psi?
Year of your car?
Old May 30, 2014 | 11:45 PM
leesvet's Avatar
leesvet
how do you KNOW there is no pressure past the FPR ????????????
how do you KNOW there IS pressure as far as the FPR ?????????
you know that this smacks of a bad pump, right?
If there IS pressure on the test gauge on the rails, there IS pressure past the FPR. period.
Fuel enters the FP-regulator, then rails or return or both then rails to injectors.
IF there IS pressure up to the FPR, there is NO WAY the FPR can dump all of the pressure if it were to get stuck and dump all to tank/return....there would be some residual tension that showed up on the gauge...20 psi or so, flickering unstable needle.
Yes, the FPR CAN get stuck, since it is only a plunger/disc under a spring. That disc can have a bad seat, the spring can break, the diaphragm can rupture or tear.
Smart money is on a bad "new" pump. Or bad electrical TO the "new" pump.
It should be easy enough to hear......
I've never heard a silent fuel pump....
<--(good oxymoron if you think it thru.)
they ALL make noise during the key ON for 2 seconds.....IF there is power to the pump AND the pump itself is good.
re: FP relay
fp electrical harness
See FSM FP relay diagnostics.
Good Luck
Old May 31, 2014 | 12:15 AM
bug6971's Avatar
bug6971
3rd Gear
96 corvette.. im working on getting a pressure tester. hopefully tommorrow.but its getting to the rail if i disconnect the quick cont to fuel rail pressure is there gas squirts. fuel pump running push in valve past FPR nothing.....disconnect return line from rail not a drop of fuel...with pump hard wired bypassing harness. when i first installed the pump it lost pressure..wtf than heard gas spraying in the tank..it busted the hose that connects fuel pump to intake line busted it wide open..just FYI.possible FPR just stuck close not allowing any fuel thru. causing line to blow/no pressure. this is 91 corvette to 96 corvette lt1 install.
Old May 31, 2014 | 12:24 AM
leesvet's Avatar
leesvet
a kinked line? if the pump blew apart a hose, that says there is a blockage between the pump and the FPR. Is the filter correct????? in backwards? wrong filter?
some have a built-in check valve....
Old May 31, 2014 | 12:34 AM
bug6971's Avatar
bug6971
3rd Gear
i guess it possible wrong filter i got one for 91 corvette the l98 motel but the pump is l98 too.40 to 90 psi figured it was plently to run stock lt1..but i disconnect the inlet hose on fuel rail it sprays fuels can run pump fuel pumps out at good rate and thats past filter..motor did sit for 5 month before install..guess in gonna remove FPR see if fuel getting that far..idk its just wierd..
Old May 31, 2014 | 12:47 AM
Curveit's Avatar
Curveit
I was gonna say... I put a new Hi Performance Pump in my '86 a couple of years ago. Confused me because I could hear it run. I discovered it was sucking instead of pushing fuel. It came with the 2 wires in the connector reversed.
To fuel problem
