Willcox Weatherstrip
Old Jun 5, 2014 | 09:34 AM
bac22's Avatar
bac22
Originally Posted by Willcox Corvette
When the weatherstrips are glued we are pretty much assured there will not be a leak. The first time we'd not use glue, I'm sure we would get a leak'r.
In most cases we use the 3M Super Black depending on the repair (or restoration) we are doing.
Willcox
You mention washing the weather stripping in the vid...what's the best way to do this? Will just good old soap work or should I wash a different way?
Old Jun 5, 2014 | 10:20 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You could use dawn and hot water, or any type of mild cleaning agent.
We have a commercial grade cleaner that we put on a rag and pull the weatherstrips through.
Old Jun 7, 2014 | 01:52 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I was going to retry fitting the B-Piller weatherstrip according to willcox video but was not able do to the fact that I already glued it across the top . In the meantime I was able to fit a length of 1/4 inch rubber hose behind the sides of the B-Piller weatherstrip and this pushed it out to where it seals. I am happy with it the way it is and will leave it that way for now.
Old Aug 23, 2014 | 10:20 PM
sjarrett71's Avatar
sjarrett71
I got my weatherstrip from Wilcox also and I also notice an "indention" at the same place, the top/rear of the window. The rubber composition looks visibly different and it looks as though it is twisted somewhat. Has there been any solution to this yet?
Old Aug 24, 2014 | 06:26 AM
eutu1984's Avatar
eutu1984
My problem was not at the top it was along the rear of the side windows going down the sides.
Old Aug 24, 2014 | 09:13 AM
sjarrett71's Avatar
sjarrett71
That's exactly where mine is. I guess I didn't explain it well enough.
Old Aug 19, 2015 | 07:27 PM
eutu1984's Avatar
eutu1984
Never got a good answer, another member posted a thread with the same problem, only thing I can tell you is to place a length of 1/4 inch hose behind it as I did. Here is a link to the thread from the other member that had the same problem.
https://www.corvetteforum.com/forums...therstrip.html
Old Aug 19, 2015 | 08:01 PM
colter's Avatar
colter
Originally Posted by awinnie
hey,
I know this is an old thread but I'm wondering if you ever got an answer to this. I am having the same issue and Willcox hasn't been a ton of help.
They've sent me the same videos but after installing and reinstalling countless times over the last 2 days, I have not been able to close the gap. I have pulled from the top/roof portion to put as much slack as possible into the sides and bolster them as much as I can, but the very bottom still has a gap where it feels like the texture of the rubber changes to more coarse and bulges out.
Does it do this with the top off and door shut?
