92 lt1
Old Jun 2, 2014 | 03:36 PM
Chevy94's Avatar
Chevy94
Navigator
Default 92 lt1
Hey All, New member here first post and it just happens to be a question. I have a 92 LT1 engine in a 94 Chevy 1500. I have in the past replaced timing chain, water pump, optispark and plugs and wires. I don't drive it much, it only has 68,000 miles. Lately I have noticed the engine straining upon acceleration. I don't have the vin number on the engine to use my scanner, and I have looked underneath and cannot locate the Vin #. Is there any other way to get my vin#. I have heard of computer flashing, will this give me the VIN so that I can scan it rather than replacing parts without knowing which actually needs replacing.
Old Jun 2, 2014 | 05:46 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The Vin number is 17 digits
Example for a 92 Corvette LT1
1G1YY23P9N5800001
1=Nation of origin US
G=Manufacturer GM
1=Chevrolet division
YY= First Y is Car Line. Second Y is Series ( Y for standard Corvette or Z for a ZR1)
2=Two door Hatchback 3 would be a Convertible
3=Code Restraint system Manual seat belt with drivers air bag
P =LT1
9=- Check digit
N=1992
5=Assembly Plant Bowling Green KY.
Last six digits=800001=Plant sequential number (example if this number was a 0ne, it was the first vehicle produced). I'm not sure why the Corvette sequence begins with a 8.
You can use the Vin above and it should work for your scanner.
Old Jun 2, 2014 | 05:54 PM
WVZR-1's Avatar
WVZR-1
What ECM are you using for the project? If you're using the ECM for the LT1 a scanner should pick up the 4 digit scan code of the PROM in the ECM but as mentioned most scanners only ask year, platform and engine to select the information in the scanner.
Old Jun 2, 2014 | 07:30 PM
bassackwards's Avatar
bassackwards
VIN should be stamped into the block behind the head shouldn't it?
Old Jun 2, 2014 | 07:39 PM
bogus's Avatar
bogus
on the block between the PS reservoir and the head, or, down by the oil temp sensor, above the oil filter. Take your pick.
bogus's Avatar
bogus
A C1500 with an LT1? That's not stock.
Old Jun 3, 2014 | 10:38 AM
Chevy94's Avatar
Chevy94
Navigator
Default Will try this weekend
1G1YY23P9N5800001
G=Manufacturer GM
P =LT1
9=- Check digit
N=1992
I do appreciate the advice, I will try it this weekend. I have had this truck for approximately ten years and love the power the LT1 gives me, I actually thought about mods, but I'm not in any hurry for mods, just want to be confident to fire her up and drive where i need to go. Thanks again
Old Jun 3, 2014 | 11:03 AM
Chevy94's Avatar
Chevy94
Navigator
thanks for the time you have taken to reply. To be honest I'm not very mechanically inclined. I will connect my scanner this weekend and let you know what happens. Thanks again
Old Jun 3, 2014 | 11:06 AM
Chevy94's Avatar
Chevy94
Navigator
I will look again if the other information doesn't work, Thank you Sir for you advice.
Old Jun 3, 2014 | 11:14 AM
Chevy94's Avatar
Chevy94
Navigator
Thanks for your input, not stock indeed was a swap
Old Jun 3, 2014 | 04:32 PM
Chevy94's Avatar
Chevy94
Navigator
Tried Scanner during my lunch hour and, could hear fuel pump relay but scanner would not connect, any ideas?
Old Jun 3, 2014 | 04:33 PM
Chevy94's Avatar
Chevy94
Navigator
1G1YY23P9N5800001
G=Manufacturer GM
P =LT1
9=- Check digit
N=1992
Tried scanner at lunch today, and I could hear the fuel pump cycle but the scanner would not connect, any ideas?
Old Jun 3, 2014 | 04:43 PM
Hooked on Vettes
Assuming you're using the Corvette ECM does your setup have a check engine indicator?
If it does you can short pin A to pin B and turn the ignition On. The Fan will come on
and you may hear the IAC valve resetting.
The Service Engine Soon indicator will flash 12 three times and any DTC's three times.
Old Jun 10, 2014 | 06:32 PM
Chevy94's Avatar
Chevy94
Navigator
Default still trying
Tried the vin numbers from the previous post and now my scanner doesn't connect. So here a quick update, just to remind you guys, there was a noticed hesitation while driving, with A/C going it was more like a hard miss then almost flooring to get up to speed. One thing I've noticed since is a rattle along the left side below the engine...catalylic converter maybe? I have read previous post so BLUF, is it the right thing to do to replace the Cat before doing any further parts replacement. Or should i spend the money on full tune up including opti, replacing seals and checking water pump, while ordering a cat deletion kit?
Old Jun 11, 2014 | 11:53 AM
Hooked on Vettes
Need to know what model and year computer you have.
94-96 Corvette computers used an OBDII 16 pin connector.
94-95 were not 100 percent OBDII compliant so most scanners don't work.
96 was OBDII compliant.
1) Can you post the numbers on the Computer sticker on the outside of the case?
2) Is the miss only when the AC is on?
3) Could be Opti but you need to check for codes. Could be the distributor cap (carbon tracking) or loose rotor.(screws are known to back off).
4) Have you verified fuel pressure?
I was assuming you were using a 92-93 Computer. 92-93 computers are know to have poor solder joints which cause all kinds of problems.
Car will run fine then stall, misfire etc...
If you have the connector like below.
You can pull ECM codes by shorting Pin A to Pin B. Any codes then flash the Service Engine Soon Indicator which is a light bulb controlled by the computer.
Using this method requires no scanner. If there any codes they may
point to your problem.
As for the catalytic converter rattle, a hard/brittle ceramic type of
material does break inside them. Some people will drop the exhaust and hollow out the cat. Unless you have emissions testing that would eliminate that problem.
To 92 lt1
