86 fuel pump HP limits
Old Jun 2, 2014 | 08:58 PM
Rob31's Avatar
Rob31
Default 86 fuel pump HP limits
How much Horse Power will a stock fuel pump support ? swapping in a new engine next week .
Its still a TPI ,larger injectors , heads , cam
Old Jun 3, 2014 | 02:34 AM
Cliff Harris's Avatar
Cliff Harris
You'll be fine at low RPM with the stock pump, obviously. It's only when you run at high RPM for sustained periods of time that you MIGHT have a problem. The way to find out is to hook up a fuel pressure gauge and monitor the pressure.
