Brake Fluid
Old Jun 6, 2014 | 05:26 PM
84wuzmy1st's Avatar
84wuzmy1st
Default Brake Fluid
Big Deal? Sign of an issue?
Old Jun 6, 2014 | 05:59 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Looks pretty dirty to me.
Old Jun 6, 2014 | 06:15 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Naaah!
Don't worry, its only the brakes. Don't need 'em until its time to stop.
Seriously.
Its time to rebuild replace the MC.
Inspect brakes, rebuild all four if leaks are present.
Drain/flush the entire system.
Why this much work?
How old is the car?
When was the last time the brakes were overhauled?
How important are the brakes?
Old Jun 6, 2014 | 06:18 PM
84wuzmy1st's Avatar
84wuzmy1st
I meant more that the front one is higher than max and the rear is lower. My brakes are less than inspiring.
Old Jun 6, 2014 | 06:19 PM
84wuzmy1st's Avatar
84wuzmy1st
supposedly the original owner did a flush and fill 2 years ago after it had sat quite a while.
It's an 85. All parts are original to my knowledge.
Old Jun 6, 2014 | 06:27 PM
JrRifleCoach
Still..... time for some serious maintenance.
The rear reservoir is a classic warning sign!
Time is short Dude. Git-r-done
Old Jun 6, 2014 | 08:26 PM
84wuzmy1st's Avatar
84wuzmy1st
The rear reservoir is a classic warning sign? I thought the rear one looked ok, I was thinking something was up with the front one.
Old Jun 6, 2014 | 08:51 PM
JrRifleCoach
What are you thinking?
That fluid is transferring rear to front?
None the less its time to start fixing.
Old Jun 6, 2014 | 08:59 PM
84wuzmy1st's Avatar
84wuzmy1st
No, I thought the overfill condition of the front could be a problem. The rear looks acceptable doesn't it?
I appreciate the info, believe me.
How do I know for sure there is actually an issue though? I don't want to replace the MC for no reason.
Old Jun 6, 2014 | 09:15 PM
Square's Avatar
Square
can you tell us what the fluid level change was.
I think everyone is assuming that both containers were full and now the rear one is loosing fluid.
If you do not know the age of the pads and rotors, changing them is probably a good idea. I did not change the front rotors and pads the first 9 years I owned my 86', because they still looked good. Finally, I found a good deal on RockAuto.com for AC Delco rotors and Wagner pads. I don't know if the old pads were cheap or petrified from age or what, but the difference was amazing. Had I known the difference would be that big, I would had done it the first month I bought the car. It still is not as good as the brakes on my C5, but it is a LOT closer than it was.
Also, if it has been 2 years since a brake fluid flush, then you are due.
Old Jun 6, 2014 | 09:32 PM
84wuzmy1st's Avatar
84wuzmy1st
Not sure where the levels started at to be honest.
I think I will start with a bleed and refill, note the levels, and then see if they change. At best guess I would think both levels were slightly below max and the rear went down and the front went up but I don't remember really noticing them before to be honest.
The car has 25K original miles, I am pretty sure the pads and rotors are original. Should I just try some new pads first?
Old Jun 6, 2014 | 10:16 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
My '85 did exactly the same thing. It was a bad master cylinder. It leaked internally. The reservoirs were level and over time they would look like yours with different fill levels.
On mine it would function almost normally. Usual braking you would not notice a problem. The one situation where I noticed a function problem was if you are stopped with your foot on the brake and kept still, the holding power would decrease and the car could roll.
You are due for a master cylinder.
Old Jun 6, 2014 | 11:13 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I would get a turkey baster and remove the old fluid and fill to just below max if the front level increases yes the master is bad. I change my fluid when it loses its clarity its cheap.
Old Jun 6, 2014 | 11:21 PM
84wuzmy1st's Avatar
84wuzmy1st
Not a bad idea We Gone. I think I will do that as step 1. Then if the Master is bad change it, the fluid, and pads all at once.
Old Jun 8, 2014 | 01:27 AM
JrRifleCoach
Here is the problem with old cars, simple maintenance items are not always simple.
You need to identify the problem area and consider the system as a whole.
DON'T cut corners on a car twenty five plus years old.
Old Jun 8, 2014 | 07:36 AM
kenmohr's Avatar
kenmohr
YEP been there done that
Old Jun 8, 2014 | 07:44 AM
C409's Avatar
C409
..... I would check the front pads for wear ... the reservoir nearest the booster (rear) feeds the front brake circuit ... as the pads wear , the fluid level slowly drops because the M/C and res are filling the piston in the caliper as it moves closer to the rotor ... when you install new pads you have to push the piston(s) back into the caliper which will transfer the fluid back to the reservoir ... your pic indicates normal levels since the front brakes do at least 80% of the braking and wear out much faster than the rears ......
To Brake Fluid
Old Jun 8, 2014 | 08:45 AM
84wuzmy1st's Avatar
84wuzmy1st
Ah... thank you for the explanation C409! I am definitely a brake noob. I have always changed my own pads and rotors on my other cars but never really paid attention to the MC reservoirs. I guess in the Vette they are just too noticeable... so I noticed... lol
I don't drive the car much, but I did the fluid transfer and I am going to see if there are any changes over the next couple of weeks of short drives.
Regardless of what I find I will most likely bleed the brakes, change fluid, and put on some new hawk pads to see if I can increase braking performance. My Daily Driver is a 98 Lexus GS400 which has incredible stopping power and is most likely one of the reason the Vette when I take it out feels a little more lackluster.
1985 Corvette 60-0 136ft
1998 Lexus GS400 60-0 114ft
Old Jun 9, 2014 | 02:43 AM
Cliff Harris's Avatar
Cliff Harris
Maybe yours is different from mine, but the markings on my master cylinder show the opposite:
Old Jun 9, 2014 | 07:34 AM
C409's Avatar
C409
..... I stand corrected ... to the OP , check ALL pads for wear ... check for external leaks ... bleed to flush the brake hydraulic system (should be done every couple of years anyway) ... and report back on any unusual braking events that you encounter ..........
