Need a weatherproof 12vdc relay
Old Jun 7, 2014 | 04:41 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Need a weatherproof 12vdc relay
I'm looking for something like this:
Old Jun 7, 2014 | 04:51 PM
WVZR-1's Avatar
WVZR-1
Any truck and fleet supplier can help you. They're used all the time for equipment. Most any off-road lamp kit uses a similar product and weather-proof product.
Old Jun 7, 2014 | 04:53 PM
ANTI VENOM's Avatar
ANTI VENOM
I've scoured the internet with searches but haven't found one yet. I prefer to attach my own wires and not use a pigtailed socket.
Old Jun 7, 2014 | 05:00 PM
WVZR-1's Avatar
WVZR-1
Then just do a JunkYard visit and grab any late 80's or 90's under-hood relays and do what you would like. There's hundreds of them just a JunkYard away. Get what you want from the latest model that you can and make sure there's a part number on it and it will ease the search for a replacement if you like what it did. You can repin the socket as you like.
Old Jun 7, 2014 | 06:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might try this link.
Old Jun 7, 2014 | 06:11 PM
ANTI VENOM's Avatar
ANTI VENOM
Thank you.......
Old Jun 7, 2014 | 09:17 PM
WVZR-1's Avatar
WVZR-1
Everything they supply should be able to be done locally "across the counter"!
OP - I'd think there's a "Fleet Pride" franchise in your area or likely several similar like I mentioned earlier in the day!
Old Jun 8, 2014 | 08:38 AM
ANTI VENOM's Avatar
ANTI VENOM
I'll check with the local dealer here. A place called 6Roblees might even have them.
To Need a weatherproof 12vdc relay
