Sheared Rocker Stud
Old Jun 9, 2014 | 03:06 PM
captainkawasaki's Avatar
captainkawasaki
Default Sheared Rocker Stud
I sheared a 3/8" Edelbrock Rocker Stud after a decent 2nd gear pull. The stud sheared off right at the top of the rocker/bottom of the poly-lock. Rocker looks ok, valve keeper looks ok, pushrod rolls smooth on glass. Everything seems ok except for the broken stud and a hole in the valve cover. Anything in particular I should be checking? Already checked for coil spring bind, double checked the alignment, etc. At this point I'm going to slap ARP 3/8" studs into it, a new valve cover, and then call it fixed. Any insight/experience greatly appreciated--captainkawasaki
Old Jun 9, 2014 | 03:35 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
check your rocker arm to valve cover clearence. check it like you would piston to valve, clay it up.
Old Jun 9, 2014 | 09:37 PM
93 lt1 vette's Avatar
93 lt1 vette
http://www.google.com/url?sa=t&rct=j...A3mxZA2xXUZNqw
Couple posts on other sites but nothing like Proform rocker failures. Stock cam and lifters?
Old Jun 9, 2014 | 10:11 PM
captainkawasaki
Crane gold race roller rockers, comp cams something or other mild cam (around .550 max lift) so nothing too wild or cheap. The stud was an edelbrock 3/8 job. After disassembly My best guess is that I over tightened the poly lock. I had one poly lock come loose so I went through with a 5/8 socket and gave all the rocker nuts another quarter turn or so. I later read that is a big no-no and it can split the tops of the rocker studs when they get hot. ARP studs are on the way, i'm going to replace them all just in case I screwed up another one.
Old Jun 9, 2014 | 10:12 PM
captainkawasaki
Clearance was fine until the stud sheared. Then, as the picture shows, clearance became a bit of a problem...
Old Jun 9, 2014 | 10:14 PM
captainkawasaki
Also in need of a left bank valve cover, center bolt, preferably with emblem. Just in case someone has one burning a hole in their pocket.
Old Jun 11, 2014 | 07:24 AM
blackozvet's Avatar
blackozvet
.550 lift with full roller rockers, 3/8 stud, lots of rpm and a standard rocker cover = what just happened to you !
if you have seen footage of inside a rocker cover at rpm you will be surprised who much everything moves around, even the studs lean backwards and forwards like a tree in the wind, thats why people use stud girdles and/or 7/16 rockers, and tall rocker covers.
Old Jun 11, 2014 | 12:20 PM
Deepa's Avatar
Deepa
sorry for the damage and you'll get it sorted out but...that is one of the coolest pictures i've seen.
Mike
Old Jun 11, 2014 | 07:38 PM
captainkawasaki
If I decide to slap a girdle on it would I need taller studs or taller rocker nuts or something? And I imagine it would no longer fit under the stock valve covers? Anyone know for sure?
Old Jun 11, 2014 | 07:42 PM
captainkawasaki
Mike
It's hard to see in the picture but the mount for the tach filter (the brown thing with the white wire coming out of each end) was coiled up by the hunk of stud and valve cover that came out. It also launched the emblem out under the car. I heard the pieces jingling down the road. I walked the section of road three times but all I found was half of the missing valve cover, the emblem, stud, and rest of the valve cover are all missing in action.
Old Jun 12, 2014 | 03:24 AM
blackozvet's Avatar
blackozvet
yes you will need taller rocker nuts, you usually get them when you buy a stud girdle,
you will need taller rocker covers too, mine are 3.5" and my stud girdle wont fit until i grind off the breather covers inside of them (which are just small pieces of alloy spot welded in so the breathers dont get oil going up them.
p.s. on the bit of cover that broke off is there any scrape marks on the underside of it ?
Old Jun 12, 2014 | 04:21 AM
ANTI VENOM's Avatar
ANTI VENOM
Moroso had centerbolt stud girdles but they seem to be discountinued. #67040 and their valve covers that fit are $500. I've seen some modified girdles as well, just google them.
I have a valve cover. I bead blasted it and it kinda screwed it up. It looks like there was pockets in the casting or something. It's not terrible but not show quality. You could fill the small pockets and then paint. I think I still have the emblem as well. Let me know.
Old Jun 12, 2014 | 06:37 AM
captainkawasaki
The piece of valve cover isn't quite big enough to tell. The rocker however is not chewed up at all except for a little on the side where it punched through the cover. I had already removed the drip tabs on the covers and I had them on a big fat cork .25 gasket for more clearance. Plus I had about 6000 miles on the combo before the shear.
Old Jun 12, 2014 | 06:44 AM
captainkawasaki
Sold! I had my covers painted anyway, and my car is an auto-x car, not a show car. Do you take PayPal or would you like a money order or certified check?
Old Jun 12, 2014 | 07:15 AM
ANTI VENOM's Avatar
ANTI VENOM
PM sent your way.
Old Jun 13, 2014 | 06:45 PM
cshuman's Avatar
cshuman
If you are using stock studs they are not long enough to give you enough engagement with he polylock. I went thru this years ago. If you look at Summits webs site for ARP studs they list a set for roller rockers. On AFR's web site for the SBC heads installation instructions they state you need to install a different stud if you are using full roller rockers. If everything lines up etc I bet this is the problem.
Hope this helps!
Old Jun 13, 2014 | 06:54 PM
ANTI VENOM's Avatar
ANTI VENOM
Thanks, we're all set.
To Sheared Rocker Stud
Old Jun 13, 2014 | 10:40 PM
Deakins's Avatar
Deakins
Usually you need to go to the longer stud to keep from splitting the top half of the poly lock off. Been there done that a few times...
Old Jun 14, 2014 | 01:16 AM
383vett's Avatar
383vett
Reading this thread, there is no way the op would need a stud girdle with a .550 lift cam. If everything is right, a 3/8" rocker stud should be sufficient. A 7/16" stud will be pretty much bulletproof with that cam. A stud girdle would be way overkill.
Old Jun 14, 2014 | 06:26 AM
blackozvet's Avatar
blackozvet
kawasaki asked the question, and your right he doesnt really need one,
Im pretty sure he does need a taller cover,
if you look at the photo with the hole in it, the rocker looks pretty dam close to that cover, or maybe thicker gaskets (like the blue ones) at least to get some clearance ?
