Did you ck the balancer? Also, it sounds like it could be the prom. I had one go bad and the SES light would blink. If i presses on the prom it would work for a while. I ended up replacing the prom and ECU.
haven't had a chance to check on the proms, i'll try holding one down and see if i get lucky, the weird thing is with the original ECU and the same proms the light would just stay lit??? just wouldn't idle without giving it gas, the new ecu with the same proms runs very well at idle and low RPM??? and i need to get on the Balancer, i haven't had time to check and wont till Saturday unfortunately
I having a issue with same car surging and backfiring, I believe I have the injector wires in wrong location at csv and #6 & 8 cylinder. Looking to get info at which connector goes where?
Sorry I have no useful info on your subject.
All the injectors on a bank have the same color wires. You should have a power wire (pink with a black stripe) and a wire that connects to the ECM. The wire that connects to the ECM is either light blue or light green, depending on which side of the engine it is on.
