Need Alternator GURU---Help
Old Jun 12, 2014 | 07:03 AM
active1951's Avatar
active1951
Originally Posted by hooked073
I have never looked at a service manual for alt dia. it is something I learned yrs ago. I understand the reasoning for that but for the most part it is hug wash. When they bench test a alt they test it just like I said but off the car. Your not running it forever just a sec or to to see if the alt can put out and to elimiate other things. If anyone does not like my susgetion I have no problem I understand. I do know at least 3 people in the last moth have used my way on her without ant ill effects and it help them dianoise their car
I had forgotten that old school technique, brings back memories.
Old Jun 12, 2014 | 07:10 AM
hooked073's Avatar
hooked073
i nget what you are saying and maybe I should explain better but in reality charging systems are pretty simple. He said he had 12 volts on the smaller terms and 12 volts on the large term that is all you need to charge. infact you really only need 12 volts on the f term for it to charge the f term excits the windings so the alt can charge.
Old Jun 12, 2014 | 07:50 AM
T. Wayne Nelson's Avatar
T. Wayne Nelson
The reason that this is stumping me is that I do have 12 V at the terminals, and it still is not charging. I have a fsm, my friend has it, I will get it back this afternoon. But again after starting the car, the large red wire on the back of the alternator reads like .1...basically nothing. I have had the alternator tested twice and it reads good. I am really scratching my head.
Old Jun 12, 2014 | 08:45 AM
active1951's Avatar
active1951
I am not sure you ever did my battery and short check. I will try again.
With the engine OFF:
1) How are you charging your battery now?
2) What voltage do you have when your battery is charged? 12.0 12.3 12.5 12.7 ?
If you answer those 2 questions we can continue.
Old Jun 12, 2014 | 08:51 AM
WVZR-1's Avatar
WVZR-1
I don't have an '85 FSM but I believe with an old 17SI alternator if you unplug the connector the voltage for terminal 1 should be maybe 2 - 4 volts supplied from the ignition through a resistance wire in the circuit. I would think a 10 Ohm resistance accomplishes that. Terminal 1 I believe should be brown. You keep mentioning 12V everywhere and I believe it's maybe important that you further define just what you have if you're looking for help. If the connector is good, the two fusible links from the starter solenoid are good and you have 2 - 4 volts at terminal 1 I'd think it should be charging.
You can't honestly evaluate it without the knowledge of the battery condition and I'm guessing from your remarks I'd likely go buy one. You've not once mentioned that you've checked things that need checked before putting a "load" on any electrical charging or cranking device.
The battery terminal needs to be at 12V to do the checks for terminal 1 and you don't seem to have that. The key I believe should only need to be in the run position. I don't believe it needs to be running.
Old Jun 12, 2014 | 02:44 PM
hooked073's Avatar
hooked073
Wayne I just walked back in the door. I am speculating that your battery is shorted. By starting the car then removing the post term off the battery you are taking the battery out of the loop and you will get a true indication if your alt is putting out. All you need for that thing to put out is 12 vlots on the f term and 12 volts on the large term you have voltage there and it does not charge then it is a bad alt.
Old Jun 12, 2014 | 03:03 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
How can the battery be shorted and still start the car?
Originally Posted by T. Wayne Nelson
With key off, I have 12 Volts to the large red wire that bolts to back of alternator, and I have 12 volts to the red wire in the plug. No volts to the white wire in the plug. With key on I have 12 volts to the white wire in the plug.
no volts to large red wire when running, both wires in the plug are 12 v
^This^ (in bold) is the "red flag", for me. you have BAT volts when not running...but
no volts...when running"? That is not right. You should have BATv there always...even if it's not charging. I'd be checking the integrity of that wire.
Old Jun 12, 2014 | 03:10 PM
hooked073's Avatar
hooked073
very good pu tom while reading it I did not pu what he was saying no good to be half asleep. course I think I told him enough times he needs 12 volts there
Old Jun 12, 2014 | 04:04 PM
T. Wayne Nelson
Thank you, thank you....The Guru finally showed up. Tom gave me one simple test...Run a wire from the main post on the altenator, to the positive on the battery. BAM!! 13.8 volts. It looks as though I have a fusible link that is out...
Again Tom, thanks..
Old Jun 12, 2014 | 04:47 PM
active1951's Avatar
active1951
Again Tom, thanks..
I think this was addressed in post 3 and 4. If this is the culprit, let us know. Did you need a new alternator or was it just the fusible link?
Old Jun 12, 2014 | 05:01 PM
WVZR-1's Avatar
WVZR-1
OP - All you've confirmed is that the alternator you were sold is doing as it's supposed to do. It passed the test on the bench, you can't expect it to do the same on the car unless the charging system is A1. You've not evaluated "squat" - you've no idea what took out your original if it was indeed bad. You've only confirmed that the new is functional.
You've got much more to do! First to do is a "load test" of at least the battery but I'd consider a load test of the entire system "on the car"! A "load test" on the car could evaluate the output of the alternator in AMP at idle, at speed and also you could confirm the starter condition in the same test. A replacement alternator may not last long when put into service in an electrical system that is less than A1.
Old Jun 12, 2014 | 05:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
His original wasn't bad. Not likely, anyway.
The stumbling block here, was that he got 12.Xv on the "BATT Term" post on the alt. (not running). The led him to believe that the B+ wire had continuity. The "no volts...when running", on the same wire was the clue (at least to me anyway).
Wayne ran a jumper wire from B+ to "BATT Terminal" on the alt, to test the BATT wire by bypassing it. As he said,
"Run a wire from the main post on the altenator, to the positive on the battery. BAM!! 13.8 volts."
So it appears that the BAT wire is losing continuity, under a load; wire, connections or fusible link is toast...it would seem.
Old Jun 12, 2014 | 05:49 PM
  #33
WVZR-1's Avatar
WVZR-1
Tom - yes it could be quite elementary. The terminal at the alternator could even be the culprit. That's often overlooked, the nut is just undone and the wire is set aside with the boot covering it. If indeed his old was a dud I only meant to mention his job is no where near done!
Old Jun 12, 2014 | 06:04 PM
  #34
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ah yes...copy that!
I made the ASSumption the his old one wasn't bad. Now I wonder.... Wayne?
Old Jun 12, 2014 | 06:34 PM
  #35
T. Wayne Nelson
Ah yes...copy that!
The old alternator was bad.. It showed bad on the tester. When I put the new one on, I got no charging. I crawled under the car yesterday and had a look, they looked fine. I will get the car up on a rack and pull the starter so I have room to see and fix the links. The problem yesterday was I was getting continuity through the fusible links, and that is what threw me. Tom suggested that one of the links might be frayed enough to show 12 v on the multi-meter, but not have enough wire left to really pull enough amps.
Old Jun 12, 2014 | 06:48 PM
  #36
WVZR-1's Avatar
WVZR-1
It's a shame you didn't have a little more warning of the failure. It would certainly have been the opportunity/excuse to do an upgrade to the CS alternator which is considered much more reliable and efficient while you were working.
Old Jun 12, 2014 | 07:12 PM
  #37
active1951's Avatar
active1951
To Need Alternator GURU---Help
Old Jun 12, 2014 | 07:14 PM
  #38
T. Wayne Nelson
The alternator was a lifetime POS from Orieley...I do not have much faith in the product...Tell me about the CS and can I get it in a 120 amp
Old Jun 12, 2014 | 07:48 PM
  #39
WVZR-1's Avatar
WVZR-1
I'll give you two links to look over. The one which I link to was a post from a CF member that seemed to have a CS 130 hanging around so I mentioned what's required for that. Later in the thread another poster mentioned a waste and to do a CS144 which I understood but the OP had asked about the other. In the end I'd suggest the CS144 for the reasons discussed in that thread. Both of those posters are regulars and very organized people. Assistance would be just a PM away I'd think if you needed any at all. There are a number of CS144's that would do. See post #11 where it's mentioned the change to the '85 upper bracket for his install. There's many higher AMP possibilities. I'll try to see if I can come up with some "clocking" information.
http://forums.corvetteforum.com/c4-t...n-an-85-a.html
Hib Halveson did a piece many years ago and I'm not real sure of some of the part #'s he mentions but I could likely confirm. Here's a link to his comments. You'll have to go towards the bottom where it's mentioned SI to CS.
http://www.corvetteactioncenter.com/...red_parts.html
I would rely on the information from the CF post and there's many other threads I'm sure that mention the swap. I'd study it well before attempting. It should require little aggravation I'd think.
Good luck!
Old Jun 12, 2014 | 08:00 PM
  #40
WVZR-1's Avatar
WVZR-1
Halverson mentions 321- 368 for a 120 AMP, I see a '92 - '93 is 124 AMP 321-552 and a '93 - '96 140 AMP is a 321-1112. I'd maybe see which your local has and compare the clocking and remember you might need to swap pulley. Do you still have your old core? I like the idea of a used if it were an original and not someone's reman. Notice on the CF thread the mention of a rear brace. The connector swap and you would be in business I think. Study and let us know!!
