84 will not start! help?
Old Jun 12, 2014 | 04:16 PM
cad90hd99's Avatar
cad90hd99
7th Gear
Default 84 will not start! help?
I have a 84 that will not start. believe it has something to do with the antitheft devise. Any way to disarm or by past this thing. When you try to start car up, antitheft light on dash comes on and says armed.
Car sat for awhile outside without door handle on car.
Any advise will help. Thanks Rich
Old Jun 12, 2014 | 05:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Does the starter crank the engine?
We need some basic info here...
Old Jun 12, 2014 | 05:57 PM
cad90hd99's Avatar
cad90hd99
7th Gear
some times. thought it may be fuel pump. still nothing. can't hear pump running
Old Jun 12, 2014 | 06:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
O.K. Hook up a fuel pressure gauge, a spark checking device, and have some one crank the starter while observing spark, fuel spray from injectors, and pressure. What is missing?
Old Jun 12, 2014 | 07:50 PM
cad90hd99's Avatar
cad90hd99
7th Gear
car now has no power. will not crank or click
Old Jun 12, 2014 | 08:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get out a test light or DVOM and start checking for power.
Old Jun 12, 2014 | 09:15 PM
cad90hd99's Avatar
cad90hd99
7th Gear
maybe the starter enable relay?
Old Jun 12, 2014 | 09:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Maybe. Test. Last guy on here who WAG'ed that, spent $23 on a relay, the time to change it, for nothing. Then he replaced hi$ battery...for nothing.
WAG'ing
Test.
This is easy. Do you have power at the starter motor? Lets start there...
Old Jun 12, 2014 | 10:04 PM
playsdixie's Avatar
playsdixie
on my 85, you have to lock/unlock the passenger door....just a shot..
Old Jun 13, 2014 | 03:23 AM
Cliff Harris's Avatar
Cliff Harris
He asked that because the anti theft system disables the starter. It seems the problem is there. The anti theft system is armed by locking the car and disarmed by unlocking the car. Sometimes the switch on the door lock goes bad. I have heard of the system not quite getting completely disarmed because the door lock was not returned to the vertical position.
You can test the anti theft system to see if it's functional by locking the door and then opening the door from the inside. The horn should honk when you do that. My car has power door locks and one time I had the window down and didn't want to find the keys in my pocket so I reached in through the window and hit the unlock button. The horn started honking, which I didn't expect.
Do other things work? The headlights, for example.
Old Jun 13, 2014 | 05:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Right. But when you then put the correct key in the ignition and turn it on, that tells the car to disable the alarm...and the car will start.
OP said car cranks sometimes,, but not now. OP said nothing about alarms sounding (horn), as would be the case if the security system were active and mot recognizing keys etc.
Testing for power at the starter is a pretty basic/easy test.
Old Jun 14, 2014 | 02:17 AM
Cliff Harris
You're thinking VATS. The car is an '84 -- no VATS. The starter disable relay is controlled by the same anti theft system that honks the horn.
Old Jun 14, 2014 | 02:29 AM
hooked073's Avatar
hooked073
WAG'ing
Test.
I agree 199%
To 84 will not start! help?
