Replacement ECM
Old Jun 16, 2014 | 09:29 PM
91 black convert's Avatar
91 black convert
Default Replacement ECM
I'm in need of a replacement ECM, for my '91.
On that big auction site I see a Cardone brand with part number 77-7727 and re-man GM's part number 88999195. They are close in price, (GM being a little more$). Any one with experience with either or would recommend one over the other?
(I have done a search in the forums and get hundreds of listings that have nothing to do with replacing ECM's. Maybe I don't know how to properly use the search feature.)
Old Jun 16, 2014 | 09:38 PM
MrWillys's Avatar
MrWillys
There's a ton on ebay if you type 1227727. So cheap you can buy 2. These came in many cars. Just keep your memcal.
Old Jun 16, 2014 | 09:39 PM
gerardvg's Avatar
gerardvg
Hi
You can get rebuilt ECM's just remember to take the removable chips from your ecm.
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Here is another from Eklers.
http://www.ecklerscorvette.com/corve...1990-1991.html
Old Jun 17, 2014 | 06:25 AM
WVZR-1's Avatar
WVZR-1
I believe for this particular ECM I like the used because they're so plentiful and generally considered reliable. I'd shop local first keeping in mind what $$ they can be purchased for. You do need to remove and use your PROM. Most of these ECM's are in W-bodied GM cars and the PROM is of no value to you. If you found one from a Corvette with a PROM and it were reasonable it would be a plus. The PROM even if not correct could be redone in any tune you'd maybe care for.
To Replacement ECM
