Monroe Sensa-Trac shocks
Old Jun 20, 2014 | 09:21 AM
solaris_vii's Avatar
solaris_vii
Originally Posted by Dt86
I think it depends on what you're looking for. I like the softer ride. I'm not auto-xing or racing. I'm cruising.
sorry quick off topic but dt86 i love your profile pic!
Old Jun 20, 2014 | 11:14 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by vert vette virgin
and I saw Bilsteins for low or lowered sports cars for $25 more ea. Our cars are low but mines not lowered. Any advantage to one over the other?
Our Vettes are low compared to other cars, yes. But to say a stock Vette is low most likely not fitting the "low" catagory.
Post a link please. I'd like to see.
Old Jun 20, 2014 | 04:16 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Has anybody put these on instead of Bilsteins? They're less than a third of the cost...and they may be made here...
DO NOT DO IT!
When I bought my 92 the PO had put these on. After 12k miles they were SHOT!
A crappy shock.
Old Jun 20, 2014 | 04:41 PM
Dt86's Avatar
Dt86
Originally Posted by JrRifleCoach
Don't matter. Heard this debate a hundred times If that was the case why not by Uniroyal whitewall sno-tyres? Drive a sports car and get the proper shock. If your an autocrosser the Bilsteins will probably not be enough.
Oh but it does matter to me. I'm not debating like you, just offering my own opinion from personal experience. And as for your uniroyal tires comment, that's just silly.
Old Jun 20, 2014 | 07:30 PM
vert vette virgin's Avatar
vert vette virgin
http://www.autopartswarehouse.com/se...Strut+Assembly)
I'm not real savvy with links but it is autopartswarehouse shock and strut section. It's B8 series bilstein.
Old Jun 21, 2014 | 01:07 AM
JrRifleCoach
Bilstein Catalog Listing
Actually, this explains a lot.
The B8 is a Sport shock. I believe they used to sell a Sport SET F&R.
It appears that only a standard front is available now with a choice of Stnd or Sport for the rear.
Also why the Sport works so well on my lowered 86.....
Thanks for the info
FYI Run a google search on the p/n and you'll find some better prices
Old Jun 21, 2014 | 09:52 AM
vert vette virgin
Thanks for the info
http://www.autopartswarehouse.com/sk...n+%26+Steering
APW has both front and rears in the B8 series listed
Old Jun 21, 2014 | 10:58 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I am getting ready to buy some new shocks and found some info on the Bilstein HD (non Z51) and SP (Z51) for comparison.
I searched for my '95 Corvette and found length and damping values by part number for these shocks.
**The only length difference between the HD or SP is the compressed length of the front shocks. The Z51 has more travel and can go slightly lower.
**The damping rates are quite different. The Z51 rates are about twice as firm in both jounce and rebound.
For me the choice is easy. I will go with the Z51 shocks on my '95. I liked them on my '94 and was investigating it to see the differences. I like a firmer ride.
HD (B6) Front (non Z51) 24-020534
Length Min/Max 10.18" / 13.56"
Damping Jounce/Rebound 106 Nm/ 76 Nm
SP (B8) Front (Z51) 24-184861
Length Min/Max 9.43" / 13.56"
Damping Jounce/Rebound 228 Nm/ 261 Nm
HD (B6) Rear (non Z51) 24-020541
Length Min/Max 9.61" / 14.69"
Damping Jounce/Rebound 134 Nm/ 114 Nm
SP (B8) Rear (Z51) 24-184878
Damping Jounce/Rebound 222 Nm/ 222 Nm
Old Jun 21, 2014 | 04:04 PM
vert vette virgin
Well I decided to go with what she was born with and ordered 4 new B6 series Bilsteins this morning. Pretty sure she's still sportin originals. At least one looks like it's been leaking so I'm hoping for a big improvement in ride quality and performance. Thanks to all who provided input on this topic!
Old Jun 21, 2014 | 04:12 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Monroe shocks are trash
Old Jun 21, 2014 | 11:06 PM
Ozzstar's Avatar
Ozzstar
Let us know if you have any improved ride quality. How many miles on your Vette?
Old Jun 21, 2014 | 11:41 PM
vert vette virgin
Just rolled past 50,000 on my cruise today. 800 of em are mine since I got her 7 weeks ago.
Old Jun 22, 2014 | 11:04 AM
  #33
Capn's Avatar
Capn
Cruising
My 84 had all original shocks, bushings, balljoints, etc.. I bought a prothane kit from summit, a new rear centerlink/toe rod setup, new tie rod ends, new balljoints, and Monroe sensatracs all the way around. I still need a 4 wheel alignment but its way better than it was. The car rides like a go kart, If I didn't install the shocks myself I wouldn't believe it had any suspension lol. Since it still needs aligned I can't accurately judge the shocks, But I lined it up best I could with a tape measure while replacing everything, It drives straight down the road and steering wheel is straight, it will "skip" a lil at 70mph on a bumpy highway bend, but I can easily stay in my lane. I don't know if this is due to cheap shocks or poor alignment. I have bilsteins on my 95 3 series and that thing rides beautiful and holds any line on any highway. but apples and oranges.
Old Jun 22, 2014 | 04:14 PM
  #34
JrRifleCoach
Originally Posted by capn
it will "skip" a lil at 70mph on a bumpy highway bend, but i can easily stay in my lane. I don't know if this is due to cheap shocks or poor alignment.
Cheap shocks, worn shocks or the wrong valving for the spring rate.
Usually its cheap/worn shocks.
Old Jun 23, 2014 | 12:10 PM
  #35
vert vette virgin
[QUOTE=JrRifleCoach;1587193647]Cheap shocks, worn shocks or the wrong valving for the spring rate.
I've mentioned in other posts that I haven't done much wrenching on cars for years but shock replacement looks pretty straight forward. Any tricky stuff involved on vettes?
Old Jun 24, 2014 | 01:52 AM
  #36
JrRifleCoach
OMG! Yes!!! Anything that looks easy will result in cuts, bruises and bleeding.
Its about a six pack job...
Old Jun 26, 2014 | 08:42 AM
  #37
Capn's Avatar
Capn
Cruising
[QUOTE=vert vette virgin;1587199647]
The front shocks are easy, I just opened the hood and changed them. The rear were easy also but I have a lift and air tools, on the ground with a jack would probably suck.
To Monroe Sensa-Trac shocks
Old Jun 26, 2014 | 12:12 PM
  #38
JrRifleCoach
...but I have a lift and air tools, on the ground with a jack would probably suck.
Yep!
Most of us just man-up and crawl underneath.
Try pulling a 700R4 on your back. Puts hair on your chest!
Old Jun 26, 2014 | 01:50 PM
  #39
QCVette's Avatar
QCVette
...Try pulling a 700R4 on your back. Puts hair on your chest!:...
Also a lot of grease, trans fluid, dirt, etc. I've done my share of them and even one on a dirt driveway. No way I have ever come out clean.
Old Jun 26, 2014 | 05:53 PM
  #40
Ozzstar's Avatar
Ozzstar
I called Bilstein this morning. It appears that the stock OEM Bilsteins do not have the same valveing that the B6 has. By replacing with the B6 HD there should be an improvement in handling according to the Bilstein rep I spoke with. Please post the driveability results with the new shocks. I am considering the B8's even though my car is a base model non Z51.
