radio bracket in 89 corvette
Old Jun 18, 2014 | 04:28 PM
PJL153's Avatar
PJL153
Default radio bracket in 89 corvette
Has anyone removed the rear radio bracket in the 89 Corvette with the Bose system?
I am going to change out the radio and it says I have to unbolt/cut the rear radio bracket out to make room.
I really don't like to cut things out so I was just wondering who has done this already and can you actually unbolt it?
Old Jun 18, 2014 | 04:45 PM
WVZR-1's Avatar
WVZR-1
Maybe try a search using your radio head model number and maybe someone has done a complete install note on what's required for that particular radio head.
I'd try also maybe searching the audio section in the same manner! I believe you'll find that if there's anything to be modified it will likely be something that requires a dremel procedure or something similar.
Old Jun 19, 2014 | 07:56 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had to remove the rear portion to fit my aftermarket head unit. It's been over 10 years, so it's safe to say, it didn't cause me any problems.
To radio bracket in 89 corvette
