84 operating temp
Old Jun 19, 2014 | 07:33 PM
84stock's Avatar
84stock
Default 84 operating temp
fixing up a 84 for my military son.
- what temp do you run the engine?
- we switched to a high volume fan and shroud. 180 thermostat. fan kicks on at 200, off around 185ish. engine routinely cycles between 180-200. on these hot days - up to 210.
- AC isn't working, assume temp will go even higher when I finally stop it from kicking my butt and fix it. I know these are hot running engines, but what really is safe? hose look good, real good, but old. wondering if I should replace with engine getting so hot. Must have AC, son had a brain injury - heat is a challenge.
even my 426 hemi runs cooler than this engine.
Old Jun 19, 2014 | 09:26 PM
Dt86's Avatar
Dt86
Originally Posted by 84stock
fixing up a 84 for my military son. - what temp do you run the engine? - we switched to a high volume fan and shroud. 180 thermostat. fan kicks on at 200, off around 185ish. engine routinely cycles between 180-200. on these hot days - up to 210. - AC isn't working, assume temp will go even higher when I finally stop it from kicking my butt and fix it. I know these are hot running engines, but what really is safe? hose look good, real good, but old. wondering if I should replace with engine getting so hot. Must have AC, son had a brain injury - heat is a challenge. even my 426 hemi runs cooler than this engine.
My 86 gets up in the 220's just as it's designed to do. You're fine.
Old Jun 19, 2014 | 09:27 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
With the original setup the fan came on around 238*, so you are not running hot at your temps.. With the a/c working, it will operate the fan also.
Old Jun 20, 2014 | 10:26 AM
corvettenorway's Avatar
corvettenorway
put on a manual switch and you can turn on the fan if it gets to hot
Old Jun 20, 2014 | 11:01 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If it gets "too hot", the fan will already be on, won't it? OP said it comes on at 200.
Up to 260 is "OK" with GM.
Old Jun 21, 2014 | 06:05 PM
TerryOlson's Avatar
TerryOlson
240 - 245 while stopped in traffic on my '84 when it's hot outside and the AC is on - been wondering if this is too hot myself and it's good to see that it isn't.
To 84 operating temp
