88 Corvette idle problems could be MAF?
Old Jun 22, 2014 | 02:13 PM
senorv47's Avatar
senorv47
Default 88 Corvette idle problems could be MAF?
Recently I replaced the intake gasket because I had a leak on the rear of the intake. I put everything back together and while I marked the bottom of the distributor and the top of the intake so I could put it back in properly, Duhh, I had the intake cleaned and of course the mark was no longer there. I adjusted TDC and set the Distributor and it started but would not stay idling. I replaced a bad Rotor cap and Rotor, I check the TPS and made sure
I had 054. I checked all the Vacuum hoses, and the fuel pressure is running about 42 psi of so. I also replaced the CTS and the IAC while I was in the process and cleaned up the EGR. While troubleshooting I disconnected the MAF and it started and idled well, but of course I had a code. I pulled it back up and the problem came back. Could it be the MAF Relay? Any help would be appreciated.
Old Jun 22, 2014 | 03:08 PM
hooked073's Avatar
hooked073
did you disconnect the timing set connection and set the timing with a timing light?
Old Jun 22, 2014 | 03:53 PM
senorv47's Avatar
senorv47
Now that I have some sort of an idle I will disconnect the connection and set the timing. I could not do it prior to disconnecting the MAF. Unfortunately my timing light crashed, so I have to pick up another
tomorrow. Thank you for your reply, every little bit helps.
Old Jun 23, 2014 | 03:54 PM
senorv47's Avatar
senorv47
TTT, Ordered the timing light online and waiting for delivery today. Any other suggestions?
Old Jun 23, 2014 | 08:35 PM
jv9999's Avatar
jv9999
If the MAF was OK before you changed the gasket, chances are it's OK now. Odds are much more likely it's something you touched. Did you set the base idle after you changed the IAC? If you set the timing without disconnecting the advance wire, it's probably way off. Vacuum at idle?
Old Jun 23, 2014 | 10:02 PM
senorv47's Avatar
senorv47
I did do a base idle after changing out the IAC that was before I did the Gasket. Today with the MAF disconnected so I could get an idle, I tried to set the timing today with the advance wire disconnected but funny I could not even see the timing mark. I looked at it before I disconnected the advance and it was a about 4 degrees BTDC, but after I disconnected it I lost the mark. it was idling about 500 - 600 rpm, probably too high. I moved the distributor around to see if I could locate it but nothing. I gave up to regroup and try to figure it out.
Old Jun 26, 2014 | 06:13 PM
J H's Avatar
J H
WOW !!!!!!!!!!!! I did the same job you did last October and had the exact same situation when I tried to start the engine. After much frustration, etc., I found out it was the MAF sensor. I replaced this and the car ran great. Even after replacing the MAF, I had a few issues since I tried "forcing" the car to run. It was running extremely rich and "soot" was covering the plugs as well as the air temp sensor in the plenum. It took a bit of time to figure all this out, but once I cleaned all this up, the car runs good.
I should say that at the time this happened, I only removed and re-installed the distributor. Similar situation to you but, I did not remove the intake that time. When I removed the intake earlier this year, this is when I discovered the sooty air intake sensor. Before cleaning this, the car ran good, but not as good as after cleaning the sensor. Closely check your MAF sensor.
Old Jun 26, 2014 | 06:23 PM
senorv47's Avatar
senorv47
Thanks for your reply, I just came in from the garage and yes it is frustrating! I rechecked that the distributor was set to TDC and not 180 out, It just will not idle unless I put the car in Limp home mode by disconnecting the MAF. Problem is I get no codes with the MAF connected. I did read somewhere that the burn off relay could be bad and does not give a code in some cases. I think I am going to replace those relays before I go through the expense of a MAF. Thanks again and keep the ideas coming.
Old Jul 3, 2014 | 05:38 PM
senorv47's Avatar
senorv47
UPDATE: Changed out the Burn off and Power Relays and still the same issues, so I guess I am down to the MAF. The new MAF should be here next week so I will provide and update then. Everyone have a great 4th of July!!!
Old Jul 18, 2014 | 11:49 AM
senorv47's Avatar
senorv47
New MAF received, now getting the dreaded code 33!! Ran down the checklist for code 33 and all tested good. Contacted the company about possible bad MAF and they were kind enough to send me another, but guess what still code 33!! Could not be two bad MAF's? I have swapped out the relays, checked all the connections and wires, TPS setting and still CODE 33 (I did reset the PCM every time) Anybody have and advice?
Old Jul 18, 2014 | 12:11 PM
Triple Black 88's Avatar
Triple Black 88
I used to have a Black 87 w/red interior that had the same problems you are having. I took it to every shop around and finally took it to a shop called Corvette Paramedics in NJ. They replaced everything in the circuit (MAF, sensors, etc...) checked all the wiring, the whole 9 yards. About a day later BOOM same problem came back, code 33 again, etc... At that point I gave up and sold it.
It's a frustrating feeling. Good luck!
Old Jul 18, 2014 | 05:28 PM
senorv47's Avatar
senorv47
Thank you for your response, yes it is very frustrating. Not sure where I am going to go now. I'm going to try replacing the TPS.
Anyone have more input please? I could use the help
Old Jul 19, 2014 | 11:10 PM
Triple Black 88
Take a look at the underside of the MAF wiring harness. I seem to remember mine rubbing against the frisbee and ate away most of the wire. Couldn't hurt to check.
Old Jul 20, 2014 | 07:55 AM
senorv47's Avatar
senorv47
Thank you, initially with the original MAF, I notice the purple wire and the blue wire had insulation stripped back, which could have been what cause the first MAF to go bad. both wire could have shorted. But since then I taped the wires apart before I put the next MAF in. I've been able to trace the wires all the way back till they disappear into the firewall and noticed no other issues. Still waiting for the new TPS to arrive this coming week to see if that is going to make a difference.
I will post my results when I change it out.
Old Jul 20, 2014 | 10:16 AM
Joe C's Avatar
Joe C
- to the OP, SLOW DOWN, TAKE A DEEP BREATH!!! sounds like you're just throwing a bunch of parts at the it without fully analyzing issue. first of all, are you 100% positive you have the distributor indexed correctly, and all spark plug wires installed in the correct firing order?
Old Jul 20, 2014 | 11:17 AM
senorv47's Avatar
senorv47
Thanks. slowing down.
1. All spark plug wires installed in the correct firing order.
2. TPS set to 0.54. Initially could not set timing because it would not idle with old MAF installed (no code at this point due to idle issue).
3. Set timing and minimum idle in limp home mode (only way it would idle)
4. Found purple and blue wire insulation stripped back (could have shorted) and used electrical tape to cover.
5. Received and installed new MAF. Car started idled and after 10-20 second threw code 33.
6. Reset PCM and installed old MAF and car would not idle again.
7. Re installed new MAF and got code 33 again.
8. Performed code 33 testing procedure from FSM and test results pointed to bad MAF.
9. Reset PCM. Replaced MAF Power Relay and MAF Burn off relay. still code 33.
10. Contacted auto place that sold me the MAF and they replaced it with a new one.
11. Reset PCM and installed new MAF and got code 33 again.
This is where I am currently. Did I miss a step? Not sure what I did wrong?
Old Jul 20, 2014 | 12:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sounds like tossing parts w/o having detailed analysis data.
From the FSM Code 33 is set when ECM has seen flow >45 gm/sec (>2.2 V) for 1second when:
-engine is first started
or
-TPS < 1/4 throttle & RPM <2,000rpm.
Since it takes 10-20 sec for the code 33 to be set, sounds like the 2nd case is the one on which to focus.
It would be very helpful to have a monitor tool to show what values the ECM is seeing when the code 33 is set.
To 88 Corvette idle problems could be MAF?
Old Jul 20, 2014 | 12:56 PM
senorv47's Avatar
senorv47
or
Yes it would, I wish I did have a monitoring tool but I've only seen pretty expensive monitoring tools. Is there something else I could use? Thanks
By the way I was wrong code sets after 3 seconds
Old Jul 21, 2014 | 11:03 AM
senorv47's Avatar
senorv47
Help....any other suggestions?
Old Jul 21, 2014 | 09:24 PM
senorv47's Avatar
senorv47
