Differential carrier cracked......
Old Jul 24, 2002 | 01:00 AM
Vettdaddy's Avatar
Vettdaddy
Default Differential carrier cracked......
Is this common and is it difficult to replace. how about the cost?
Pick up car tommorow from other misadventures.
Thanks Cal
Old Jul 24, 2002 | 03:36 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Differential carrier cracked...... (Vettdaddy)
I will assume it is a 44 carrier. Most of them I have seen that cracked were due to bolts being displaced and wedging between the ring and the carrier. Never seen one just crack for now reason.
Best bet is to find a used replacement, generally ranging from $1000-1400. Some have found cheaper, just luck.
Old Jul 25, 2002 | 12:21 AM
hookedup's Avatar
hookedup
Default Re: Differential carrier cracked...... (Vette92)
I just broke a spider in a D-44 this month and a chunk was caught between the case and ring gear. Punched a hole in the bottom of the case, but it's not in a stressed area so it should weld up fine.
Good luck,
Dave :cheers:
Old Jul 25, 2002 | 12:47 AM
Vettdaddy's Avatar
Vettdaddy
"cracked were due to bolts being displaced and wedging between the ring and the carrier " Not sure if I know what you are describing.... this is cracked on the top arm going out to the right wheel.....Post regarding welding which part...
Thanks Cal
Old Jul 25, 2002 | 12:51 AM
kenfusion's Avatar
kenfusion
Vettdaddy,
If you have a dana 36 you might be in luck. I have a spare dana36 carrier for sale for $75.00 + shipping.
Thanks,
Ken
Old Jul 25, 2002 | 05:00 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Differential carrier cracked...... (kenfusion)
In either case, d44 or d36, you'll need to pull the rear end out. I'd see if your friendly welder could repair the crack, depends on how bad it is. If it's too much to fix, the guy with the d36 carrier for $75.00 + is a good deal. :smash: :smash: :smash: :smash:
To Differential carrier cracked......
