Ignition fun
Old Jun 26, 2014 | 09:05 PM
Slow86vette's Avatar
Slow86vette
Default Ignition fun
I'm guessing it is something simple but I have an msd blaster coil for my hotcammed lt1 and I have power going to the plugs on the coil but not getting any spark. Any ideas?
Old Jun 27, 2014 | 07:10 AM
C409's Avatar
C409
..... The Ignition control module (mounted with the coil) tells the coil when to spark based on input from the Opti-Spark ... most chain auto parts stores will test the ICM for you ... you can try a known good coil in place of the MSD or the OEM coil if you still have it .........
Old Jun 27, 2014 | 05:50 PM
Slow86vette
I appreciate the idea. I've done a swap on an early tpi car, and I'm honestly tired of looking at it since I hate wiring haha I replaced the coil thinking maybe the contacts wore out and no change. I will go test the voltage at the icm and if it's enough then I will go buy a new one. Hopefully I get spark. I'm ready to haul *** again.
To Ignition fun
