speedo
Old Jun 27, 2014 | 04:09 PM
19774x4's Avatar
19774x4
Default speedo
91 vet speedo does not register on dash, help please what to look at and where to look
Old Jun 27, 2014 | 05:40 PM
WVZR-1's Avatar
WVZR-1
First thing to check would be the VSS maybe. Does your car have C68 (auto AC)? If it does you could see if it registers on the AC control panel. You just can't see it or it's 0 MPH? Does it display miles? How about trip?
Old Jun 29, 2014 | 11:40 AM
19774x4's Avatar
19774x4
Default speedo
it just shows o mph all the time, no miles, no trip. thanks
Old Jun 29, 2014 | 02:25 PM
WVZR-1's Avatar
WVZR-1
The total miles aren't displayed? 68681 or whatever the miles of your car are. You didn't mention the C68/auto AC. Do you have that or not? You could get someone with a good scanner to attatch to the ALDL and see if it can be picked up from there. Have you checked for a bad connection at the VSS? LH rear of the transmission. Silver dollar sized sensor with two wire connection. It should be very obvious.
Old Jun 30, 2014 | 08:04 AM
19774x4's Avatar
19774x4
Default speedo
thanks everyone for the help, found a bad wire at the trans
To speedo
