Single Plane EFI
Old Jun 28, 2014 | 01:40 PM
C409's Avatar
C409
Default Single Plane EFI
Old Jun 29, 2014 | 07:43 AM
blackozvet's Avatar
blackozvet
ok what is it ??
Old Jun 29, 2014 | 10:18 AM
85MikeTPI's Avatar
85MikeTPI
Your fuel spray is going against the airflow. The fuel distribution and control won't be much better than a TBI unt. Good luck.
Old Jun 29, 2014 | 02:22 PM
C409's Avatar
C409
..... Really ??? .........
Old Jun 29, 2014 | 02:24 PM
C409's Avatar
C409
Originally Posted by blackozvet
ok what is it ??
..... Edelbrock SY1 ... A.K.A. Smokey Ram .........
Old Jun 30, 2014 | 09:08 AM
C409's Avatar
C409
..... FYI ... This is a crossram intake manifold that was available back in the late 60's early 70's Trans-Am heyday with single or dual quad tops ... the injectors are aimed at the mouth of the intake runners (inside the box) which then travel to the opposite side of the manifold and into the cylinder head ports ....... I'll get better pics up after the manifold comes back from the fab shop , including some shots of what it looks like under the lid ... the biggest obstacle here was keeping the fuel rails between the reinforcing structure on the underside of the hood when closed , and we did ...........
Old Jun 30, 2014 | 10:53 AM
rklessdriver's Avatar
rklessdriver
That was a quite valuable intake manifold. Less than 1500 of them were ever sold to the public before Smokey and Edelbrock had a falling out over the royalty amounts.
FYI the SY-1 was never offered with (2) four top. Offy, MT, GM and Edelbrock all did offer (2) four Cross Rams at one time or another but the SY-1 was a single 4150 only.
I have one that I got back in 1989 (for $50.00) and have used it on a few engines.
It takes ALOT of carburation because of how big the plenum is. It makes a nice TQ curve and has good power output between 3500 RPM and 7000 RPM on a 350-360 inch engine. It's RPM limited on 380 and bigger inch engines and honestly it's sweet spot is engines that make between 450-550HP because of the small (relitive to todays racing intakes) runner cross section.
Good luck with it.
Will
Old Jun 30, 2014 | 07:25 PM
C409's Avatar
C409
Good luck with it.
Will
..... Yeah , it was the Edelbrock STR-10 that was dual quad ... the Offy came with three tops ... single 4bbl , dual 4bbls , and tri-power ... that one is VERY rare ... the Offenhauser version is still available new ..... Congrats on your new motor for the '84 ... gone over to the dark side ? ... carburetor ? ... awesome power output ... .......
Old Jul 1, 2014 | 09:35 AM
rklessdriver
Thanks.
Alot of hard work went into it. Gonna be a real competitive engine I think.... I tried not to show "it's full potential" over there as some of the folks I race against were lurking.... but some of them other Cats on YB are pretty sharp and noticed right off that I was purposley killing alot of HP (at least on the dyno sheet I posted).
Time will tell if I can get the rest of the car where it needs to be or not.
My 1984 has always been carburated (during it's life as a race car). A Carburetor was just easier for me to make the kind of HP I needed to run with those guys.
My 1992 still has the 2925 Super Victor single plane EFI conversion.
Will
Old Jul 1, 2014 | 12:52 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
ok what is it ??
A souped up Crossfire!
Cool looking project.
Old Jul 1, 2014 | 05:09 PM
C409's Avatar
C409
Thanks.
Will
..... Well good luck ! Looking forward to seeing some ET slips ... very impressive numbers especially since you were holding some on the dyno ..... I've got a 421 build that I'm working on right now , though I doubt it'll be in the same zip code as yours is power-wise , It should be pretty strong ... now if I could only get Mike Jones to deliver the bumpstick so I can start assembling it .....
Old Jul 1, 2014 | 05:31 PM
C409's Avatar
C409
..... Thanks ... This one turned out nice ... can't wait to get it on the engine dyno and see how it compares to a couple of other intake ideas I'm working on ..... I'm hoping that the fuel injection will tame this beast ..... after looking under the lid I was amazed that ANY fuel ever made it down the runners in anything but pure liquid form ... But its the runner length that got my attention ........... Stay Tuned ! .........
Old Jul 1, 2014 | 06:17 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
its the runner length that got my attention.
BINGO!
I've been saying that for years...in a different context (called "CFI"). It is an excellent runner length, IMO and with the base you have you've circumvented the runner cross section issue...with the MPFI, you've also circumvented the fuel distribution challenges. Keep us posted!
PS I always day-dreamt about using this to solve CFI/Cross ram fueling issues, but keep it stockish/stealthy looking; Injector inside the plenum....
Hard to find/size injectors for your power level though.
Old Jul 1, 2014 | 06:38 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old Jul 1, 2014 | 08:00 PM
ex-x-fire's Avatar
ex-x-fire
So that's what you did with the intake that I sold you, cool project.
Old Jul 1, 2014 | 09:09 PM
blackozvet's Avatar
blackozvet
Ok, a crossfire on steroids !
Old Jul 2, 2014 | 10:57 AM
C409's Avatar
C409
........... Thanks for the intake ... ... I also have an Offenhauser Crossram being set-up for EFI ... that one will be done quite a bit differently , fuel injector placement-wise ... the Offy has longer runners ............
To Single Plane EFI
Old Jul 2, 2014 | 08:53 PM
C409's Avatar
C409
..... I guess the crossfire IS a crossram ... the original idea was to build a long runner intake manifold that would fit under the hood ... kinda like a flat tunnel ram ... unfortunately , these were intended for carburetors and the design didn't lend itself to streetability , much like a tunnel ram back in the day ....... BUT , with EFI and injectors placing the fuel in a better place without needing to make so many sharp turns , I am confident that the mid-long runners and their better cross sectional area will make for some interesting dyno numbers .......... Stay Tuned ! ........
Old Jul 3, 2014 | 06:15 AM
blackozvet's Avatar
blackozvet
Its like you have become the mad professor on here
Good Luck !!
Old Jul 10, 2014 | 10:44 PM
C409's Avatar
C409
..... I just got this one back from my welder/fabricator ... another Dyno test intake manifold ... Holley Strip Dominator that has been EFI'ed ............ .....
One thing to notice is the rearward position of the thermostat bridge ... plus , its LOOOOOW at only 2 1/2" above the china rail ..........
