1991 corvette
Old Jul 3, 2014 | 05:56 PM
nico12play's Avatar
nico12play
2nd Gear
Default 1991 corvette
I have a 1991 corvette. When I put in drive it will not move. I have to put it in overdrive. Then after I get up to 30mph I can shift it back to drive.Does anyone know what I should do to fix this problem?
Old Jul 3, 2014 | 07:33 PM
ch@0s's Avatar
ch@0s
Is your indicator off? Mine was and N was OD.
Old Jul 3, 2014 | 07:55 PM
leesvet's Avatar
leesvet
yep...the linkage hold down bolt on the trans will get loose and that is enough to throw the indicator off by 1 or 2 notches. Even the adjustment under the console cover plate can become sloppy. Its linkage...so there are adjustments. I lost reverse once...it was still there, just NOT in the "R" slot on the console..
To 1991 corvette
