MSD 6AL
Old Jul 24, 2002 | 06:55 PM
dsg049c's Avatar
dsg049c
Default MSD 6AL
OK I just rebuilt my motor and trans... I think I need to add a MSD6AL because I had to go with 30lbs injectors. Now MSD recomends that when you install the MSD that you upgrade your cap and rotor with a performance cap and rotor with brass terminals. I have a 96 LT4 and the optispark cannot be upgraded only replaced.
1. Here is my question- Will the MSD burn up the cap and rotor in the stock optispark and will everything run ok with the MSD6AL.
2. Do I need the MSD?
:confused: :confused: :confused:
Old Jul 24, 2002 | 06:58 PM
James94LT1's Avatar
James94LT1
Default Re: MSD 6AL (dsg049c)
Yes the MSD will be just fine with your stock opti.
I've ran one on my car for about 4 years now.
nsimmons's Avatar
nsimmons
well on my car, standard hei, ive burnt 3 caps. I have my msd unhooked right now and a special bushing on its way from summit. That should stop the melting. On an opti though? got me.
Old Jul 24, 2002 | 07:01 PM
James94LT1's Avatar
James94LT1
Default Re: MSD 6AL (nsimmons)
Nick,
I had that probloem with the HEI dist. before myself, that bushing should fix that for ya!
Old Jul 24, 2002 | 07:18 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
No worries on using it with an Opti. You don't need it though. Not really necessary unless you are juicing or blowing.
stroyer's Avatar
stroyer
The MSD 6AL will work fine with your optispark. Had one on my car (93) for 4 years with no problems. Might have to remove your tach filter, but save it just in case you go back to stock.
Scott
Old Jul 24, 2002 | 07:31 PM
gtsyellow's Avatar
gtsyellow
Default Re: MSD 6AL (stroyer)
you did prom work right? a 30lb seems like it would run a awful rich on a stock program
Old Jul 25, 2002 | 10:57 AM
dsg049c's Avatar
dsg049c
Yes I am having the computer reprogramed through Ed Wright. I just added a LT4 Hot Cam and had the heads ported and polished and while they were putting it together might as well upgrade the injectors.. With that configuration do you think I will need the MSD?
:chevy :chevy :chevy
Old Jul 25, 2002 | 11:25 AM
ZylaRace's Avatar
ZylaRace
Need the MSD,...... NO
Will adding it do anything major for your performance,..... NO
If you just want it, and wanna lighten your wallet,.. go for it.
Old Jul 25, 2002 | 11:51 AM
dsg049c's Avatar
dsg049c
Default Re: MSD 6AL (ZylaRace)
Thanks for the update... I guess I just saved some money...
:D :D
To MSD 6AL
