Ordered My MSD Digital-6+ and HVC Coil
Old Jul 24, 2002 | 07:09 PM
StealDads67's Avatar
StealDads67
Default Ordered My MSD Digital-6+ and HVC Coil
I cant wait for them to come in. It will be here on Friday.
I got the...
-MSD Digital-6 Plus
-MSD HVC Coil
I got the coil for it because MSD designed it for the Digital-6 so why not right. It was expensive, but you pay for what you get. Its probably not gonna make a huge difference at all.. but its gonna be great for the NO2 and I like the 2 stage rev limiter for when I get to the line. Should be cool stuff. What do u guys think? Keep in mind Im not looking to get much power from it until other mods and gettin the RPMs up there... but I will always have it and in the future it will help more and more
Old Jul 24, 2002 | 07:15 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Ordered My MSD Digital-6+ and HVC Coil (StealDads67)
Is the HVC coil a direct replacement for stock? I am running the MSD Blaster coil because it is plug and play. Can't go wrong with the 6 though.
Old Jul 24, 2002 | 07:20 PM
StealDads67
Default Re: Ordered My MSD Digital-6+ and HVC Coil (Vette92)
Blaster HVC Coil, PN 8252
The Blaster HVC Coil is right at home on the street or strip. The Coil is designed to produce maximum power with an MSD 6 Series Ignition Control. Special windings and material were chosen by MSD engineers to efficiently produce High Voltage and Current. Low primary resistance allows the coil to take in all of the MSD's energy and instantly step up the voltage combined with a high amount of current. This combination delivers a powerful spark to the plug for complete combustion in the cylinder.
The coil windings are encased in epoxy and held secure in a heavy duty aluminum housing. The tall secondary tower accepts an HEI style plug terminal and boot and heavy duty vibration mounts are supplied for a secure mount.
I figured I had to buy it when it said... " The Coil is designed to produce maximum power with an MSD 6 Series Ignition Control. "
Old Jul 24, 2002 | 07:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
If you want to upgrade your coil, you want to use the MSD-8226 for '92-96 LT1 engines. You don't want to use the one you ordered.
Old Jul 24, 2002 | 08:49 PM
95AquaC4's Avatar
95AquaC4
:yesnod:
Old Jul 25, 2002 | 05:14 PM
StealDads67
Why is that???..... MSD said they designed it for use with the Digital-6 plus ignition??? I guess Im gonna have to send it back then... oh well :confused:
Old Jul 25, 2002 | 05:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
It may be designed with that ignition box in mind, but your car uses a different type of coil.
Old Jul 25, 2002 | 06:48 PM
Nathan Plemons's Avatar
Nathan Plemons
Yes, perhaps, but doesn't his 91 use a different style coil than the LT1?
Old Jul 25, 2002 | 06:50 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Ordered My MSD Digital-6+ and HVC Coil (Nathan Plemons)
Nathan, not sure what I was thinking. I thought he had a '92 (wasn't even putting the color with the year). Been posting too much I guess. I think I got this post crossed with another one in my mind. Forgive me Kevin.
Chris
Old Jul 25, 2002 | 06:52 PM
scorp508's Avatar
scorp508
I'm planning on getting the Digital 6. I want to utilize the dual stage rev limiter for launching.
Old Jul 25, 2002 | 08:48 PM
95AquaC4's Avatar
95AquaC4
Chris
Ah...forgive me too!! never looked at the year either!
Old Jul 26, 2002 | 01:26 AM
StealDads67
Default Re: Ordered My MSD Digital-6+ and HVC Coil (95AquaC4)
Oh ok no problem guys... Ur intentions were good... everyone thinks my car is LT1.... Scorp... The Dual Rev limiters is ONE of the main reason i got it.... I think that is so cool for launching. The other is for the Nitrous retard.... Ill keep you guys updated on everything
Old Jul 26, 2002 | 01:36 AM
scorp508's Avatar
scorp508
Take advantage of the startup timing retard feature also.
Old Jul 26, 2002 | 01:40 AM
StealDads67
Default Re: (scorp508)
Ofcourse... Im gonna take advantage of all the features... Im just saying those were the main things that attracted me to it...
Im gonna setup the Rev limiter with my line-loc switch...
Old Jul 26, 2002 | 01:42 AM
scorp508's Avatar
scorp508
:confused:
You use a line-loc for a burnout, not as a trans-brake. At least.... I don't know anyone doing that. :)
Old Jul 26, 2002 | 12:21 PM
StealDads67
IT WILL BE HERE TODAY.... I CANT WAIT!!! lol I get a little excited when I get things for my car..... :D
What do you mean by trans-brake?? I think the line-loc with the rev limiter on the switch will be perfect for launchin.... What do you think... Anything else that might work better?? Thanks
Old Jul 26, 2002 | 12:44 PM
scorp508's Avatar
scorp508
You have a 6-speed. You use the clutch to launch.
Old Jul 27, 2002 | 03:53 PM
TreyZ28's Avatar
TreyZ28
hey kev,
hows it going.
you finally got it huh? Let me know what happens and if it was worth it!
I forgot you Zip, but i have an accel unit coming to my house. dont want to hit the stock limiter on my nitrous :nono:
by the way, that guy i know at slp is trying to grab an airfoil for ya ;)
I talked to your dad the other day too... he said hes got a few projects going which scared me and i decided not to ask too many questions about them!
Z06?
talk to you later man!
good luck with the ignition set up! make sure u zap lil mike with it!
ohh yeah, u get that bottle yet?
To Ordered My MSD Digital-6+ and HVC Coil
