instrument cluster bulbs
Old Jul 24, 2002 | 09:09 PM
jeffie86/96's Avatar
jeffie86/96
Default instrument cluster bulbs
OK I pulled out the bulbs from the instrument panel and went to the auto parts store. Is there a different holder for 194 bulbs?? The old bulbs have heavy straight wires and 194s have small ones bent around the glass base. Or is my dash not from an 86?? :confused:
Old Jul 24, 2002 | 09:19 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: instrument cluster bulbs (jeffie86/96)
The 194's will replace the bulbs in the information center. The bulbs behind the speedometer and tachometer are 882's I believe. You can find them at Napa, and O'reily autostores, or at least I did for my '88 model.
J
Old Jul 24, 2002 | 10:04 PM
mash557's Avatar
mash557
Don't remember the number, but don't go to dealer, they are about $20 there. They are halogen bulbs so have the same cautions as fog lights and such. I got mine at O'Reilly's
Old Jul 24, 2002 | 10:46 PM
jeffie86/96
Default Re: instrument cluster bulbs (mash557)
I was going by the info on the cluster troubleshooting page that said to replace them with 194s but I am probably mistaken , I went to O-Reillys and got em. :eek: Almost 8 bucks a piece!! Can't anything be cheap.
Old Jul 24, 2002 | 11:45 PM
JonM's Avatar
JonM
Seems O'Reilly doesn't need a gun to stick people up...That bulb should be no more then 2 bucks...
Old Jul 24, 2002 | 11:51 PM
jeffie86/96
Default Re: instrument cluster bulbs (JonM)
My bulbs look different from those. They have straight heavy wires.
Old Jul 25, 2002 | 04:35 PM
LarryK 87's Avatar
LarryK 87
the 882's have straight stiff leads that plug into the OEM sockets, The 194's pictured above will not fit the existing OEM socket ( i read the same article as you about replacing the 882's with 194's) The sockets are differant, so i bought the 1/2" sockets ( for the 194's) These unfortunatly will not fit correctly into the PCB ( the lock point rotates the contacts on the sockets past the contacts on the PCB, so i got the 5/8" sockets which will line up correctly, but are too big to fit the opening... solution... a small rounded finish file, a little judicious filing on the PCB... and poof, a neat, tight 194 conversion for $8.00 total ( all 4 bulbs and sockets ) Have not really noticed any differance in the light ( 194's are not as bright as the 882's ). And they run much cooler and at 1.99 per pair at any Auto parts store... cheap. BTW the entire "Adjustment" took about 1 - 2 hours.
Now if i could just find a source for some blue acrylic sheets, i would also change the dash color.
:chevy
Old Jul 26, 2002 | 01:15 PM
jeffie86/96
Default Re: instrument cluster bulbs (LarryK 87)
I just decided to replace the two bottom ones and leave it. My car is kind of a POS anyway. :lol:
Old Jul 26, 2002 | 03:31 PM
-=Jeff=-'s Avatar
-=Jeff=-
the 194's will only fit the 89 cluster from what I remember
To instrument cluster bulbs
