fx3 ride control module - newbie!!!
Codes are likely:
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
There are codes 41 and 42 possible also. A code of 23 will set also if the car is keyed to run 3 times without moving. That code should go away once the vehicle is driven. To clear the codes I believe the same jump of A & C will accomplish that also when done in 2 second intervals a total of three times. I'll try to post back but that's best I recall.
Were you supplied the Factory Service Manual with your purchase? If NOT you need to consider the purchase of one. Published by HELM for GM there would be two volumes. You want ONLY those with "red covers"! Expect to pay something $85 - $100 for them used. Anything less is a good deal. You need BOTH books.
Here is a link to how the ALDL is pinned and other uses of the connector:
http://www.corvettebuyers.com/c4vettes/codes.htm
Here's another that will be useful later:
http://tech.corvettecentral.com/2011...trouble-codes/
