Cooling fan
Old Jul 13, 2014 | 09:16 AM
jseremba's Avatar
jseremba
Default Cooling fan
Hi Everybody,
I own a 1984 4plus 3 Corvette. I have the diagrams and the shop manual. My problem is this. I changed the relays, CTS and the fan switch. Passenger side of the engine. Oh and the fan motor works. When the car gets to 205 degrees the temperature the switch should turn on at. It blows the cooling fan fuse. No mater how high a fuse I put in, it blows. So how do I find what is pulling the extra voltage?
Thank you
Joe
Old Jul 13, 2014 | 09:53 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Sounds like a wiring error. Did you do any rewiring?
Before you changed the coolant fan switch did the fan work?
What fuse is blowing the fan fuse?
Are you using a replacement fan relay? (could be wrong relay)
If the fusible link is blowing can you spin the fan blades manually which would confirm the motor isn't locked up?
Old Jul 13, 2014 | 01:14 PM
leesvet's Avatar
leesvet
I can see how the error happens......black ground wire to/in relay circuit with a black w/red stripe as the hot wire to that same relay. If someone did not understand the power/ground design of the C4 electrical system, they'd assume that both of these were grounds,.
To avoid future problems, just remember this. ALL the power wires in a C4 are HOT all the time, some need to have the key ON, others no.
The ground wires are broken and run thru switches, sensors and controls to complete circuits and operate everything.
This is a short sounds like. Installing bigger and bigger fuses is begging for disaster. Wires melt, things start to smoke. Because there is a hot wire that's been tied directly into the ground circuit. I'd guess around the relay,.where the temp sensor completes a GROUND circuit, not a hot.
Where did this number --> 205 degrees come from? 'Cause that's not where the fans SHOULD come on....
That real fan temp is 228. That's where the fans start.
if you installed some aftermarket fan or temp sensor kit, its wired wrong.
Sensors and switches are ground "loops" that jump from one to the next. When the end is reached at a relay or switch its to complete the ground path since the positive path is/was already complete.
Old Jul 13, 2014 | 02:09 PM
jseremba's Avatar
jseremba
1) I did not do any rewiring. Last year I noticed that the cooling fan was not cooling. I did some checks and thought it was the fan. I bought a fan and had the same problem.
I replaced the relay on the driver side fender. Finally I hot wired the fan so I can turn it on and off. I just hate having it like this.
You are correct I think it is a short. But how do determine where? Take apart the wiring harness and look for breaks?
205 degrees came from the switch I bought. I am old school and 228 degrees scares me. I will agree that these cars like heat. But, as of now the fan switch is set for 205 degrees. same wiring as the original fan switch.
Just trying to figure out how to find the short.
Thank you. The information you posted may be helpful to me.
Old Jul 13, 2014 | 02:13 PM
jseremba's Avatar
jseremba
No the fan did not come on. And I replaced the relay so I bought the fan. Then I realized that the original fan did work and I was blowing fuses.
The fuse blows as soon as the fan starts. I can tell because. When the car hits about 207 the fan moves and then the fuse blows. So it wants to work.
All of the wiring looks original.
I think that this car had an accident. It has headlights from a newer model year 1988. So could a wire have been damaged in the accident. If it happened?
thank you all
Old Jul 13, 2014 | 02:41 PM
jseremba's Avatar
jseremba
Okay I am looking at the manual page 8A-149 and it has instructions but, I am at a loss to understand them.
check fuse, okay
voltage to relay I am thinking that the blue wire should have 12 volts from the fuse.
Check relay operation? how do you check it?
Check CTS? how do you check it? bypass the switch?
Old Jul 13, 2014 | 03:26 PM
jseremba's Avatar
jseremba
check fuse, okay
So I got my probe and I also took a good look at the wires. They look correct. The hot fro the battery goes to a wire that goes to the relay and to a fuseable link. There is power on both sides of the link and power going to the relay.
I disconnected the relay and jumped the red to the red and black wire. The fan did not run.
Yet I can run a wire from the batter to the fan and it will run.
Any ideas?
thank you all
Old Jul 13, 2014 | 04:02 PM
Hooked on Vettes
You didn't say what fuse is blowing.
You say the cooling fan worked but didn't cool so you replaced the relays and fan motor.
Then you say you installed a lower temperature fan switch and Hot wired it.
Can you explain how you hot wired it and why? :
Have you verified the front of the condenser and radiator aren't clogged with leaves and plastic bags?
Does the wiring at the cooling fan relay look like this where all of
the insulation wiring has shrunk back and could short to each other?
http://i171.photobucket.com/albums/u...elayfaults.jpg
Old Jul 13, 2014 | 06:06 PM
Hot Rod Roy's Avatar
Hot Rod Roy
We have some confusing information here, jseremba. You say the fan starts to spin when the temp hits 205* or so, then the fuse blows. Then you say the fan doesn't run when you connect the red wire to the red/black wire. I don't think this could be true.
I have a 205* CTS in my '84, and mine works just fine.
I'll take a wild guess the relay is wired wrong. Notice the diode in the schematic across the relay coil? In a "normal" relay, it doesn't matter which side of the coil goes to the +12v. In this relay, the cathode of the diode must go to the +12V., or you'll blow the fuse when the CTS closes! Sound familiar?
The relay case probably identifies which terminal is the cathode of the diode. If not, you should be able to measure the low resistance direction of the coil. If in doubt about your measurement, check your meter with another loose diode to identify the cathode.
Old Jul 13, 2014 | 07:12 PM
jseremba's Avatar
jseremba
You are correct. That did not make sense. So I went and retried it. And when I put a wire from red to red and black the fan ran.
Can the relay or connector be the problem? The relay is new. I bought it last year when I first had this problem. The relay has never been used. Can I get a new connector?
Sounds familiar, yes.
My connector is red, blue, white and green, black and red
on the relay is a picture. open switch(red) then a diode (blue and White Green) than a wire (black and Red)
So could the black and red and the red be in the wrong spot?
I have a volt meter so checking the resistance on the cathode is done how? sorry just learning auto electronics.
this is great thank you.
Old Jul 13, 2014 | 08:47 PM
Hot Rod Roy
The Red and the Blk/Red wires are fat wires. They can be reversed, no problem. The Blu and Grn/Wht wires are smaller wires. These must not be reversed. The Red will be "hot" (+12v.) at all times. The Blu will be hot when the key is on, and must be wired to the cathode terminal of the relay coil. If you jumper between the Grn/Wht wire and ground (key on) the fan should run. If you pull the connector off the CTS and jumper that wire to ground (key on), the fan should run. The engine does not need to be running for these tests.
The fan should also run at any time your a/c is on (engine running).
Quote: "I have a volt meter so checking the resistance on the cathode is done how?"
First thing is to learn how your meter works. They're not all the same. With a loose diode, and your meter on 1x resistance (ohms), reverse your test leads to determine if the resistance of the diode is lower with the red wire or the black wire of your meter on the cathode of the diode (the stripe on the diode). Write this down, as it's easy to get confused. Check your relay the same way. Mark the relay to identify the cathode terminal. This terminal must go to the hot wire. (Since your relay has a diode symbol on it, your job is easy!)
Old Jul 14, 2014 | 06:51 AM
jseremba's Avatar
jseremba
First the key off testing is exactly what I was looking for. Thank you. Oh my ac has no Freon . Will the switch still engage?
okay, loose diode does that mean a diode not in a relay? Sorry really crawling when it comes to auto electric.
Old Jul 14, 2014 | 03:06 PM
Hot Rod Roy
With no freon, the a/c won't work, and the a/c pressure switch won't work, so it won't turn on the fan.
"Loose": Not confined or restrained; free. Not put up in a container. Readily available. (/Webster)
Hooked on Vettes asked you about the condition of your relay socket. Is it damaged? Unplug the relay and check the resistance between the Blu wire and the Grn/Wht wire at the connector. Should be "infinity".
Verify the Blu wire is hot with key on. (I know this is a repeated test)
Verify cathode terminal marked on the relay goes to same terminal as the Blu wire of the socket. Cathode is the __ end of the mark, not the >, as shown on the schematic.
The "loose diode" test was an attempt to help you understand your meter. Since you have mentioned your relay IS marked, you don't need to do this test.
If all of this checks out okay, your relay is bad.
Old Jul 14, 2014 | 05:24 PM
jseremba's Avatar
jseremba
I do not care if it is a repeat test. thank you for the help.
Okay I own a dictionary. I wanted to find out was that an auto electronics term. Sorry.
I thought that the AC had to be charged. but I will check the resistance. The relay is new the connector looks like crap.
Old Jul 14, 2014 | 07:06 PM
jseremba's Avatar
jseremba
So I turned on the key and the blue wire was hot.
I took the circuit tested clipped it on ground and then took the probe and put it in the CTS wire. The fan did not start.
I then jumpered the Green/white and blue still no fan.
I turned on the multimeter and set it to Ohms it read one.
When I put the multi meter on the blue and green/white wires it read 1. Is that infinity?
Old Jul 14, 2014 | 07:08 PM
jseremba's Avatar
jseremba
So the arrow points to the cathode.
Old Jul 14, 2014 | 08:02 PM
jseremba's Avatar
jseremba
okay so decided to see if the wires were crossed I took the blue moved it to the green/white and visa versa. The car got to 205 and the fan did not come on. I then disconnected the relay and jumpered the red/black to the blue and blew the fuse.
To Cooling fan
Old Jul 15, 2014 | 01:47 PM
Hot Rod Roy
Hooked on Vettes identified your problem. How do expect this to work with a melted socket?
okay so I decided to see if the wires were crossed I took the blue moved it to the green/white and visa versa. The car got to 205 and the fan did not come on. I then disconnected the relay and jumpered the red/black to the blue and blew the fuse.
Who suggested anything like this???
Yikes!!!
I'm done.
Old Jul 15, 2014 | 03:55 PM
jseremba's Avatar
jseremba
Yikes!!!
I'm done.
the reason I moved the wires was someone suggested they could be crossed. So I tried it.
someone also said that if I jumpered the black and red to the blue the fan should run.
And I also tried grounding the CTS wire and the fan did not run. With a new fuse of course.
so how do I determine what is wrong with the blue or cts wire. Are they shorted. The cts wire does not have power.
did not mean to disappoint you all
Old Jul 16, 2014 | 01:41 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
After reading this thread, and re-reading, I did not find anywhere that suggested jumpering the back/red wire to the blue.. This might work if the fan fuse were the same rating as the fusible link, but it is not, it's only a 3 amp fuse. Shorting the CTS wire to ground should operate the relay, if not check the resistance between the sensor wire and the green white wire s/b 0 ohms or very low with 12v on the blue, with key on.. You will get a low resistance reading between the blue and white/green, possibly 1 (infinity would be what you see with the meter on resistance with the leads not connected to anything.. You need to confirm that the wiring to the relay is as shown in the drawing that Hooked on vettes provided and that the relay is as Roy pointed out..
With the switch in run, check for 12 v on the green white wire, this should show the 12v from the blue wire through the relay coil..
